Old 06-18-2009, 07:38 PM   #1
4DSEVEN
4DSEVEN's Avatar
Anyone trim the frame to fit your headers?
I already have a set of chrome headers that are brand new and were given to me still in bubble wrap.
They are a bit tight and I was thinking of trimming a bit off the top frame rail to ease them in. They will only fit if I trim a bit.
Is this something that should be avoided or will taking a bit off not hamper the rigidity of the frame?
4DSEVEN is offline   Reply With Quote
Old 06-18-2009, 08:20 PM   #2
54 jimmy
54 jimmy's Avatar
Re: Anyone trim the frame to fit your headers?
i would go with the bfh route if possible. dimple/dent the frame where you need it to fit. is is safer and a dent/dimple won't weaken the frame like trimming would. it also depends on where you ned the room. some pics would help.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 06-18-2009, 09:44 PM   #3
57ToyBox
57ToyBox's Avatar
HAVE YOU LOST YOUR MIND ?!?! LOL J/K
-So have you considered all the other options instead of notching the frame?
-Can you use higher motor mounts?
-Will your local Rod Shop take those new Headers in on trade for another set that will fit?
57ToyBox is offline   Reply With Quote
Old 06-18-2009, 10:41 PM   #4
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
dimple the header...so what if its chrome(remember it dont get ya home but headers do!)
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 06-18-2009, 11:44 PM   #5
Kim57
Kim57's Avatar
If you trim the frame you could weld in a heavy steel tube to add strength. I've seen it done on the rear when guys need extra clearance for lowering their trucks. Here's a pic of what I mean.
Kim
Kim57 is offline   Reply With Quote
Old 06-19-2009, 08:58 AM   #6
robin58
No engineer by any stretch of the imagination, but imho it's completely different than the example given by Kim57. When trimming for an axle to sit and welding in the curved support, the force is going downwards and distributing the load. If you remove the are on top though, the force is 100% still on the bottom regardless of what kind of support you give it. To explain what I mean I just took the lazy way and flipped Kim57's picture over. I'm sure someone with some engineering background could probably comment better. FWIW the PO of my truck had done precisely 4DSeven wants to do just to clear a stock manifold on the passenger side. I rewelded a patch into my frame and boxed that area just to support any potential weaknesses there were that I couldn't see.
robin58 is offline   Reply With Quote
Old 06-28-2009, 07:11 AM   #7
4DSEVEN
4DSEVEN's Avatar
Here's what I ended up with.
Old 06-29-2009, 12:20 PM   #8
mylow53
mylow53's Avatar
i did something similar but my frame was boxed in that area you might want to consider some bracing. my original frame was cracked near the passenger front cab mount. this is a high stress area defiantly worth some extra plating especially since your adding weight. my 53 cracked with the original 6 in it. mind you a crazy high schooler was driving it at the time
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
