Old 06-18-2009, 08:17 PM   #1
MrBlue
MrBlue's Avatar
Which Mufflers?
Greetings,
The 72' we purchased has 3" exhaust with glass packs from the headers to the tailpipes. Sounds nice (& loud). But with the law, I'm sure my son would surely would draw some red-light attention. So we need to install mufflers. We like the Flowmaster and Magna Flow. Anyone have any suggestion(s)?
Victor
MrBlue is offline   Reply With Quote
Old 06-18-2009, 08:22 PM   #2
fiyaweed06
fiyaweed06's Avatar
Re: Which Mufflers?
I love the sound oh! i mean the price of the Thrush Welded mufflers i have them on all my cars except the stang.
fiyaweed06 is offline   Reply With Quote
Old 06-18-2009, 09:23 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Which Mufflers?
Just a small $.02 worth. Unless you have a big block engine and you are driving it hard, that 3" exhaust maybe costing you some gas mileage and performance. Is the exhaust a single pipe or duals? If it is duals, then exhaust companys will tell you that the exhaust flow may be to slow or "Lazy" and is causing you some reversionary losses in your system.
The idea is for the exhaust to move along "Cooling" as it exits from the engine. That cooling effect is causing a slight vacuum effect pulling the gasses away from the headers and making the exhaust scavenge the fumes from the cylinders. Flowmaster will tell you that for a modified 350 to 383 cubic inch engine a dual 2 1/2" exhaust is the borderline for the amount of gases you will create, from that point on you are walking in an area of losses being more than gains. If it is a single exhaust system, then the 3" tubing is well worht the effort.
I prefer the Flowmaster sound to the Magnaflow sound, myself.
piecesparts is offline   Reply With Quote
Old 06-18-2009, 09:41 PM   #4
70cst
70cst's Avatar
Re: Which Mufflers?
Very good point piecesparts... I will have Spin Tech's with factory manifolds connected to 2 1.2" pipes once my project is out the door. Flowmasters will be lower cost than Spin Techs ...but I just liked the sound of Spin Techs better but flowmasters will do you just fine.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-18-2009, 10:11 PM   #5
ZombieWeinerDog
ZombieWeinerDog's Avatar
Re: Which Mufflers?
spintechs or flowmaster series 40's
if i had a big block (and Money), i would have a cutoff that i could switch between straight pipes and mufflers. best of both worlds
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 06-18-2009, 10:23 PM   #6
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Which Mufflers?
The spintechs sound very nice especially with big blocks
I just put on Goerlich mufflers on mine - they sound quite wicked -
3" true duals back to the rearend with turndowns
As mentioned above pipe diameter makes a big difference the larger the pipe the more noise it will make
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
