PROJECT 7DEUCE
![]() Join Date: Dec 2002
Headlight switch?
Does anyone know if the headlight switches are the same from 72 to 87? they both look the same? Any help here guys....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
its all about the +6 inches
Re: Headlight switch?
i would search a parts store on line and look at the part number for the two.
That, or if you have the two parts, I would look at how each terminal is labeled in the switch where the plug goes. |
#3 | |
![]() The Delco switch D1588 fits from 1966 to 1981 but was used on later years also D1652D D1506A D1506AC D1588 has terminal 7 are used on the later years here are some pics top left is D1588 t topright is D1651D bottom left is D1652D They are all priced less than $25.00 Last edited by mbgmike; 06-19-2009 at 12:27 PM. Reason: added number |
