Gettin It One Pice At A Time
I am lost, I need help.
OK, a few days ago I was working on a Jerry rigged electrical work I did to a plug on my wiper motor. I used some good wire and couplings. I took my time and made all the connections tight. I went it to make sure the wipers worked and they didn't so I got to looking at the fuses and everything looked good. no breaks or melting. so I though that maybe I screwed up on my fix. so I cut it all up and Jerry rigged it just like I had it before. Still Nothing! so I went out and got a multi-meter and I checked to see if I was even getting volts to the wires at the plug. No suck luck. I tried it every which way I could think of. wiper switch on, off,and wash mode. I tried having the leads on both wires and both ways and tried having the ground, grounded to the frame. Nothing! so I thought, maybe its the switch! so I got it out and I had the ground, grounded to the dash. went to every connector and got nothing! I tried it with the ground on the black wire, nothing. tried it with the plugs on the switch and switch on. Nothing! So, NOW WHAT!!!! LOL
![]() ![]() The plug on the left is the one I was working on. ![]() Here is the switch. ![]()
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby Last edited by 79gmcc15; 06-18-2009 at 08:39 PM. |
Arrived on a Pale Horse
Re: I am lost, I need help.
Was the key turned to the on position (forward)?
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
Do you have power at the fuse?
67 Chevy K20 LWB Fleetside project 85 GMC K10 High Sierra LWB, 37's, 8 lug rears, 4.10's project 86 m1009 blazer, 6 in lift, 35's, driver 69 c10, 307, long bed, 3 speed, driver 07 Dodge 2500, cc, lb, cummins turbo diesel 00 z28 camaro, ls1, 6 speed, rarely leaves the garage |
well, here is problem number 2 most of the names on the fuse block is gone. so I don't know which one it is. I pulled all the fuses out and they were good.
problem solved! I found a pic of a fuse box with labels and found out the fuse holder for the wipers.... well......didn't have...a fuse!
