Old 01-03-2003, 06:13 PM   #1
RED72blazer
urban fourwheelin
RED72blazer's Avatar
what size fuses
does anyone know what type of fuse should be in the front harness? does anyone know what I'm talking about? it's the little short fuse that is inline. thanks
red72
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 01-03-2003, 07:04 PM   #2
72K10
Book (72 service manual) calls for 4 amp for both fuses near the junction box, but I have to put a 30 amp fuze in the one between the battery and the junction block, or it keeps blowing. Try 4 amp first. Hope this helps!
RLTW
70C10
72K10
72K10 Cheyenne
72C10 Cheyenne Super
72K10 is offline   Reply With Quote
Old 01-03-2003, 07:13 PM   #3
RED72blazer
urban fourwheelin
What is the junction block? the fuse panel? I'm really confused, I have four short fuses under the hood, two on each side right where the core support meets the fender. thanks I'll go try 4amps
red72
Old 01-03-2003, 07:17 PM   #4
72K10
Red, I was referring to the two fuses closest to the battery. The junction block is the bolt that sticks out of the fenderwell on the battery side. You should have lines running to it and then out from it to the battery. The fuses on the drivers side I don't know the amps.
RLTW
70C10
72K10
72K10 Cheyenne
Old 01-03-2003, 07:22 PM   #5
RED72blazer
urban fourwheelin
I think we are taking about the same thing. But I don't have any fuses between the junction block and the battery. I'll have to get pics if the new fuses don't work. thanks 72k10 for the quick responses.
red72
