Livin the good life!!!
![]() Join Date: May 2009
Looking for engine or engine builder in Dallas Area
I am in the process of restoring a 68 SWB chevy truck. It has a 350 in it right now which I am going to pull in the next few weeks. I'm not sure if it is a 2 bolt or 4 bolt main. Won't know until I pull the motor. I want to make a 383 stroker out of it if it is a 4 bolt main. Does anyone know of a good reasonable reputable engine builder in the Dallas area that can take this 350 and make a stroker out of it for me? If so please let me know I'm lookin!
Thanks, James
James Current Project 68 SWB factory A\C cab Daily Driver 2004 Chevy 2500 HD Crew Cab 4x4 6 inch lift Proud owner of a 1932 Ford Roadster "Zppn By" ![]() http://67-72chevytrucks.com/vboard/c...pic57166_1.gif |
I am a Referee of life.
Re: Looking for engine or engine builder in Dallas Area
If you're building an engine under about450-500 HP the two bolt is plenty strong.If you're going to build for more and use a factory block have it machined for 4 bolt main caps.The aftermarket ones are splayed and are usually considered stronger than the factor5y 4 bolts.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#3 | |
When you say aftermarket ones are splayed what do you mean by that? Aftermarket what? Main caps or blocks?
![]() Join Date: Mar 2005
I use City Motor Supply (Harry Hines and Forest Lane) for most of my machine work and have never had any problems. I don't know that I would want them building a supper throw down high horsepower motor but for stock to mid range stuff I would go with them every time. For me, they have been faster and cheaper every time. I'm taking my BB there next week...... I hope.
OK here maybe I can help
you got Blaines ahh ok sometimes depending on the machinest American Gasket samule blvd you get what you pay for City Motor -- I was told by my grandma if you cant say somehing nice!!! E-P-W noth dallas ohh yeah again you get what you pay for. Imo Last edited by myfirstcarwasa73trk; 06-18-2009 at 11:14 PM. |
The mains are splayed. The outermost holes of a 4 bolt main go in at an outward angle (kind of similar to the shape of the block if you're looking at the bottom). Both the main cap and block are splayed. IMO, no need for this unless you're running REAL high horsepower.
Wouldn't want City Motor building me anything for supper. Super is what I meant.
Splayed Mains.... Last edited by Dynomutt; 06-18-2009 at 11:33 PM. |
motor exploder
StrokerMotor.Com
(214) 350-4979 10530 Shady Trl, Dallas, TX 75220 Call them. They were one of my accounts when I worked at Cloyes Gear (I managed the high performance parts line). They have a nice shop, use good parts and know what they're doing. I wish i could remember the owners name, he was a super cool cat and I have no qualms recommending him. I wouldn't let Blaine's change my oil. Dang sure wouldn't want City Motor building my street stomper either. Not trying to bad mouth, just speaking from what i know to be true, from working in the engine parts industry!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Last time I tried to find some info from Stroker Motors, they were gone (out of business?).
motor exploder
well, that's a shame then... I left Cloyes in 2006, so I wouldn't know past that. I do, however still have some contacts down there, so I can make some calls if need be.
D&P Machining Service
Garland TX Dave Pluebell 972-840-2242 Stock, Custom, & Performance Engines specializing in 348's & 409's
#13 |
Under Construction
Not in Dallas, but Allard has a great reputation....
Jimmy Allard Auto Machine 324 Allard Road, Ennis, TX 75119 (972) 878-9821 as does Wells... Wells Cylinder Heads 2441 Shiloh Road, Midlothian, TX 76065 http://www.wchengines.com/index.html (972) 723-5115
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 06-19-2009 at 10:11 AM. |
#14 |
![]() Join Date: May 2002
if you are interested, i have a 355 at my parents house in houston. has all the machine work already done, bored .030 over, pistons and everything. to make this a 383, all that you would need is the 400 crank. i don't have any pics of it at the moment, but i'll give you a good price on it. just let me know
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
#15 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I am dealing with this hell myself right now. If you start dealing with machine shops and figure your time in on the deal, those crate engines look so much better. I can't find a machine shop in DFW worth using.
#16 |
I have a great machine shop that does all our work here for the shop. When we built my motor he did all the machine work for it, but if this motor blows up I am definetly using a crate motor next time won't be going thru all that machine shop non sense..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#17 | |
Gearhead and audio junkie
#18 |
425hp409
![]() Join Date: Oct 2008
When you make a 383 stroker out of a 350 block, the block has to have clearances ground in it for the crank to clear. You can't just drop a 400 crank in it and go.
I have used City Motors to build a 383 stroker for me with no problem. They install new cranks in all their strokers. Try M&M Machine in Dallas. Mitchell is a sole proprieter and operator. He does great work, and alot of dirt track engines. He builds all my HP engines, balances and blueprints them. I turn my cast crank 454 built by him 6500 with no problem. M&M Machine 10637 Wood Dale Dallas, 75228 214-328-8399 |
#19 | |
Junior Member
It is a small world.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#20 | |
Hay Team!!
68SWBChevy If you are up for a small drive.....give him a call he will treat ya right. There are machine shops all over but most of them are to the south of you or to the west of you. Bud Morgan Arlington Machine Mike Smith Farris Racing Ray Mac Kim Barr just to name a few
1972 Chevrolet Cheyenne LWB "Orange and White" 8) Last edited by Outlaw72; 06-19-2009 at 05:57 PM. |
#21 |
Hay Team!!
Here is the engine Howard Farris built
1972 Chevrolet Cheyenne LWB "Orange and White" 8) |
#22 |
![]() Join Date: Aug 2008
I use performance automotive on samual blvd. close to big town blvd. They are a little $$ but the quality of work is awsome. they will set down with you and find out exactly what you will be using the truck for or what you want and build to those specs.
#23 |
Calvert's in Denton
Jim Anderson had a shop like a city motors where they cranked out about 70 motors a day, but he has retired and now does motors out of his home. He's done 5 for me and is very reasonable. Engines Xtreme is the name, he's in Flower Mound. Take 121 west to 2499 and he's just east of 2499 and 3040. I saw Kim Barr in another post above and he does really nice work. |
#24 |
Just wanted to follow up on this. I dropped my block off yesterday at Farris Racing Engines. I dealt with Shane Farris. I got pretty good vibes about the whole deal. He said he'd get me out this week (vat, bore and cam bearings). I will update when I get the block back.
#25 |
Under Construction
sweet....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
