crewcab large hump or small hump?
Ive done a search and I am still confused.I have a 91 crewcab 2wd with a
4l80e.In one thread it was stated that all crew cabs/burbs front floor pans are large hump.the why do they sell carpet kits for both large and small hump?
http://67-72chevytrucks.com/vboard/s...d.php?t=304940 |
Low & Fast!
Re: crewcab large hump or small hump?
Anyone?
I found this after I posted,but still baffled as to why they market carpets for small hump if they are all high hump.
http://forum.73-87chevytrucks.com/sm...88158#msg88158 A thanks to Chris as this is from his site.
I seem to recall that you can get a small hump or a large hump in a Suburban (small hump for 2wd, large hump for 4wd).
I don't believe that original thread you are referring to is correct. Expanding on that, then, the crew cab would probably share that same floor, since Sub/Crew are "common" from the B pillar forward. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-20-2009 at 07:28 AM. |
I just picked up a 2wd crew cab, and pretty sure it has a small hump. Cab is going on a 4wd frame, and converting to stick, so have to cut the hump from the donor truck. Now I have to find a red carpet from a 4wd or stick crew, not easy to find where I am.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
