Old 01-03-2003, 08:58 PM   #1
sakohntr
sakohntr's Avatar
How durable is the rockwell transfer case
I am gonna make my one ton dump truck four wheel drive and just happen to have an extra 4 spd and rockwell setup. How durable were these? I dont know if this one is gear or chain drive. Anyone broke one of these before. I have seen the chain drive 203's break. thanks for your time bruce
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 01-03-2003, 09:19 PM   #2
srhart71
You might want to talk with PONT. I believe he blew his up not to long ago. He could probably tell you how much abuse it took.
srhart71 is offline   Reply With Quote
Old 01-03-2003, 09:23 PM   #3
ckhd
ckhd's Avatar
I'd put it up against a 205 any day. The problem is that there are almost no parts available to fix them when they break.
I like the shift pattern better too. Keeps the shifter forward and out of the way.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 01-03-2003, 09:42 PM   #4
sakohntr
sakohntr's Avatar
parts available
No problems with spare parts up this way. many in the junkyard......
Old 01-04-2003, 07:21 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
It's gear drive.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-04-2003, 09:38 AM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
I'm satisfied with mine and if you've got access to parts, your good to go.
About spare parts, I'm needing the coupler that is inside the adapter that connects the SM465 to the Rockwell - a couple board members have possible leads, but I'm always asking around to see if anyone has one available - have not been able to find one locally yet.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-04-2003, 02:56 PM   #7
Pont
I need another Barley Pop
Pont's Avatar
I recently lost the Rockwell t-case in my truck but not because it's a weak transfer case. Mine has had a leaking gasket since I've owned the truck and I ran it low on gear oil. If parts were easily available in my area for these Rockwells, I would go through and rebuild mine. Compared to the NP205, I think they are at least as tough. These are not chain driven cases.
I am going with the NP205 so I won't have to deal with parts availability in the future. They quit making the Rockwell T221 in either 68 or 69 and parts are not as easy and will not become an easier to get in the future. This was the deciding factor for me to go with the 205.
If I had a good one or if mine was still good, I would not hesitate to use it. I'm a huge fan of the Rockwell for it's low rear output for the rear driveshaft. It really helps with driveshaft angle on rigs with larger suspension lifts like mine.
Hope this helps........
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 01-04-2003, 07:19 PM   #8
sakohntr
sakohntr's Avatar
case's
Then its offficial. I am gonna try it.
Old 01-04-2003, 08:19 PM   #9
Zeke
Active Member
My dad has a 69 4x4 with a rockwell transfer case. bought it new and has over 500,000 miles on it with no trouble at all. only complaint is it weighs a ton (only when he had to change clutch)
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 01-05-2003, 02:04 AM   #10
Rod
I plan on a 1 ton dually 4x4 one day too... got my 205 sitting here... sold my 4 spd 205 one a while back shouldnt have but it was from a 77. A little different but would have worked... my 205 is from an auto now,... so not sure what Im going to do... but I would like a dana 60 front... how 'bout you?
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-01-2006, 04:14 PM   #11
JAKES 68GMC
Aluminum slot wheels rule...
Re: How durable is the rockwell transfer case
I've got a Rockwell underneath the bench thats just like new. All it needs is a thrust washer (some reason it only had one ), but its not for sale. Very rugged t-case IMO.
JAKES 68GMC is offline   Reply With Quote
Old 05-01-2006, 04:47 PM   #12
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Lots of abuse on mine. No problems as of yet. 104k since 1967.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 05-01-2006, 07:40 PM   #13
1969 GMC
1969 GMC's Avatar
I didn't like mine, and how it sorta blew up on me. I could have taken it apart and did all new seals, but it was my DD at the time. Ran low on oil and the input bearing jumped ship. Never hear of this problem with NP205's, because they are not as tall as the Rockwell. Also, I don't know how common PTO's are for these since they use the weirdo pattern.
For what its worth, you can still buy EVERY new bearing and seal for them at car parts places. Hard parts will be your problem, but you probably won't break any of them (with the exception of the drive sleeve). From when I did the swap, it looks like a SM465/NP205 sleeve could be made to work.
I think that the divorced T221 would be a good case, if you made sure it didnt leak. The married case has the weak 10 spline connection, and even then yours may or may not be worn. If its really well worn, it could be just one dumped clutch away from leaving you stranded.
my 2 cents.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-01-2006, 08:58 PM   #14
JAKES 68GMC
I guess I'm dumb, because I can't understand how one of the 10-spline sleeves could strip out. Anybody want to fill me in on that info?
Old 05-01-2006, 11:40 PM   #15
1969 GMC
1969 GMC's Avatar
I cut my finger on one of the edges. Scary huh?
1969 GMC K2500
1996 Honda Accord
Old 05-02-2006, 10:07 AM   #16
Americanrider
Simple, the more splines you have the more surface area you have to "carry" the torque load. 10 coarse splines does not have as much surface area as a 27 or 32 fine spline coupler. Just in the same way you can put more torque on a fine thread bolt than a corse thread because it has more surface area to distribute the load evenly.
http://www.offroaddesign.com/NP205tech.htm
Americanrider is offline   Reply With Quote
