65 suburban vortec 5.3 bagged
question best tank for bagged truck?????
i am looking for a gas tank right now and my hopes are to lay frame i am looking at the blazer or suburban gas tank it looks like the blazer tank would drag on the ground i also am on a budget so the CPP $500.00 aluminium fuel cell is to much i also am putting in an efi engine any suggestions would be a great help.
right now i am looking at the CPP metal blazer tank,sending unit, and straps for $245.00 shipped to the door. just want to make sure before spending the cash!!!!!!!!! |
#2 | |
Re: question best tank for bagged truck?????
Resistance is Futile
How about a Summit fuel cell?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
is there a specific summit fuel cell that seems to be the best fit and can you get the 30 ohm sending unit for it?
Well, the Summit fuel cells are generic race-type items. Mine has a 0-90 ohm sender; I'm replacing my gauges so I bought an Autometer to match the tank. I was assuming that your weren't using the truck like a truck if you want to lay frame, so you just mount the tank in the bed. I also thought price was the biggest factor, so I think you can still get an aluminium tank for about 200 bucks.
I thought you mite be interested in considering one.
protrash64 thanks for the info how many gallon did you get?
