06-20-2009, 12:35 PM | #1 |
Out of the carpool lane.
Vibration between ~55-65mph
I have a nasty seat-o-the pants vibration that I feel between about 55-65mph. I don't feel it before that and it diminishes after 65 although the vibration cycle increases with overall speed. The vibration is more of a shudder that happens about 1 every second at 55-60mph and then the rate increases the faster I go yet it feels smoother the faster I go.
I've had my wheels balanced several times at 2 different shops. Could it be my driveline? I've noticed it sticks out about 1-1/2" and most dl shops recommend 3/4"?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
06-20-2009, 02:54 PM | #2 |
Project Junkie! Fishing Poor!!
Re: Vibration between ~55-65mph
Could very well be your problem. Didn't you tell me you have a single piece driveline? What is the diameter? WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
06-20-2009, 03:26 PM | #3 |
Moderator
Check the U-joints on your driveshaft.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
06-20-2009, 04:33 PM | #4 |
It's all in the timing
I agree with LeddZepp,I would check the U-Jionts.Also your drive shaft may be out of balance,I would have it checked.If you replace the U-jionts and your drive shaft is not balanced correctly they will just wear out again.
06-20-2009, 10:42 PM | #5 |
Firedogs 68 had a vib between 65 n 70 then the tranny went out. Replaced the tranny n torque converter now no more vibs at any speeds. Just wanted to throw that out there. But I'd check the rest of the driveline first.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
06-21-2009, 03:42 AM | #6 |
Gone to greener pastures
Brad,
Check your carrier bearing and check your drive shaft/U-joints to make sure that they are "in phase." Larry
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
07-13-2009, 01:57 PM | #7 |
Skinned knuckles
Something I've recently learned.. Loosen your rear u-joint at the axle and see if it slides back and forth. The u-joint needs to fit tightly in between the nubs on the "yolk" on the rearend. If not, it needs to be replaced.
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 |
