Old 06-20-2009, 03:36 PM   #1
69GMCLonghorn
69GMCLonghorn's Avatar
Can't Find Spring Bushings
Ok, I'm in a bind. I've been to every shop in town and no one can find me a set of bushings for my 1-ton rear leaf springs. I want to pull mine apart and replace the bushings and hardware, but I don't want to pull it apart until I have what I need. I just stopped at a really good 4WD shop close to me. The Energy Suspension catalog lists a part # for a 67-71 4WD 1-Ton rear leaf and a 73/87 2WD 1 Ton leaf, but not a '69 2WD 1-ton leaf (did you get all that??). Does anyone know if I can use either of these?
69GMCLonghorn is offline   Reply With Quote
Old 06-20-2009, 03:58 PM   #2
mbgmike
Re: Can't Find Spring Bushings
The part is AC Delco 45G15382 . We sell them for $26.00 but we our out of stock and I just checked with the Warehouse and they are out to. I can call on monday if you would like to see about an ETA
mbgmike is offline   Reply With Quote
Old 06-20-2009, 04:06 PM   #3
69GMCLonghorn
That would be great. Can I assume these are the factory rubber bushings and not poly? I don't really need poly, but if they're available, I'd take 'em. Any info would be great. Thanks!
Old 06-20-2009, 04:23 PM   #4
mbgmike
let me check on monday then and see how long it takes
Old 06-21-2009, 12:15 AM   #5
69GMCLonghorn
Anyone else out there with leads on the spring bushings?
Old 06-21-2009, 03:22 PM   #6
Tim Christian
Tim Christian's Avatar
if you have the meaurements of them I might just have them in stock
Tim Christian is offline   Reply With Quote
Old 06-21-2009, 11:26 PM   #7
69GMCLonghorn
Tell me what measurements you need. It's kind of a pain to measure in there, but I'll try.
Also, the guy at the shop I went to said the original bushings may have been "vulcanized" into the eyelets? Has anyone heard of this? He just said they might have to be torched out, which isn't a problem. I had just never heard of this before...
