Old 06-20-2009, 04:26 PM   #1
Irishpilot
How to attach '72 Cheyenne door panels to '71 doors?
I just picked up a really nice set of original '72 Cheyenne interior door panels and was trying to attach them to my '71 doors. The original inserts are metal and are screwed in with 1/4" screws. It looks like the '72 panels have plastic push-type screws that are around 3/8" diameter. Anyone know how this is supposed to go? I would rather not drill my doors, but I will if that is how to get the panels to fit. Thanks for the help!
1971 C-10, 406ci, restoration begun!
406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners.
Irishpilot is offline   Reply With Quote
Old 06-20-2009, 07:01 PM   #2
john
member #16
john's Avatar
Re: How to attach '72 Cheyenne door panels to '71 doors?
Could you remove the capture nuts, and find oversize fasteners to work in the square holes? They make all sizes of those christmas tree things.
john is offline   Reply With Quote
Old 06-20-2009, 08:01 PM   #3
Irishpilot
The fasteners are only on the bottom four holes. The top four are just holes in metal.
Old 06-20-2009, 08:31 PM   #4
jerry moss
Born Psycho
jerry moss's Avatar
the window regulators and door regulators will not work with the 72 panels, the stems are about 3/8" longer on 72s. i learned this the hard way when i put 72 panels in my 69 and tried to attatch the window cranks and door handles and they kept poppong back off. i ended up putting 72 guts in both doors. i had already drilled the holes out for the plastic push pins so i was stuck.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 06-20-2009, 09:00 PM   #5
Irishpilot
Yeah, I was noticing that as well. This might me more work than I'm really ready for. Plus I'm on the fence because I'd like to keep it as close to '71 interior as possible.
Old 06-21-2009, 03:20 AM   #6
red71c10
The Red Menace
red71c10's Avatar
Unless you are in love with the '72 panels, sell 'em and get what fits the '71. If you don't like the metal panels, you can always upgrade to vinyl.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
