Old 06-20-2009, 05:38 PM   #1
pat123
Pat
pat123's Avatar
Tail light trim?
Im haveing some trouble figuring out how the tail light trim clips clip to the trim? Pics would be great. i have a factory assembly manual but its hard to understand the illustrations.
Thanks for the help
pat123 is offline   Reply With Quote
Old 06-20-2009, 09:35 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: Tail light trim?
No pics but the trim piece has 4 tabs very easy to see. That is were the clips go. One corner of the clip goes under that tab and the other goes under the bent over ridge on the other side oppisite of the tab. The long tail of the clip pops into place under the same ridge to hold the clip in place.
Are you sure you have the right clips??
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 06-20-2009, 10:31 PM   #3
pat123
Pat
pat123's Avatar
heres a pic of what i have. i put them on but im not 100% sure if their right, and dont want to remove them cause i had a hell of a time. the green one i modified a bit to look more like the black one because i didnt have enough of the back ones. the second pic is how i put them. sorry its not the greatest work but the yellow is the trim and the blue is the clip shown from the back side.
Old 06-20-2009, 10:39 PM   #4
pat123
Pat
pat123's Avatar
sorry i meant to say
the second pic is how i put them on.
Old 06-21-2009, 03:06 AM   #5
sameyrasmea72
I have a crappy monitor, so I can't see good, but for sure you need to turn the clip 1/4 turn. And maybe flip it overI can't tell. Some of the clips have a support brace that pushes againts the trim. That brace goes towards the trim and adds pressure.
72 Cheyenne Super
Old 06-21-2009, 03:18 AM   #6
sameyrasmea72
The arrow points go under the two lips (the big tab and the other lip). Then take the long thin wire and pull it back till it pops in under the lip too to hold the clip in place.
72 Cheyenne Super
Old 06-28-2009, 01:00 AM   #7
pat123
Pat
pat123's Avatar
ahh! That works better
Old 06-28-2009, 03:23 PM   #8
pat123
Pat
pat123's Avatar
PS. Trim before bumper
