walmart carpet
Has anyone used the cheap carpet you can get at walmart or the auto parts stores that comes in a roll? Was wondering if anyone has used it and if it worked out ok. Was thinking of buying some to cover up the floor in my 65 chevy c10. Any feedback and pics would be appreciated.
Grandpas truck, my dream. This is my truck. There are many trucks like it but this one is mine. 65 Chevy C10 Fleetside |
Re: walmart carpet
just buy a roll of astro-turf!
Just here to tinker
![]() Join Date: Jun 2008
Re: walmart carpet
I used to use it a lot when I was a broke teenager...it works fine as long as you put floor mats down. If you rub against it too much it starts pulling apart and looks like matted sh*t. But there is nothing wrong with it. The black actually can turn out pretty nice if you take your time....
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Re: walmart carpet
Thanks for the input there Corts60. I will be putting mats down on top of it. Maybe I will do a how to when I do it for others that are on a budget. I'll at least take lots of pictures. I first have to patch up some holes I have on the floor. One on the drivers side and one on the passengers side. Anybody else have any input or pictures of their do it yourself cheap carpet installs.
Resistance is Futile
Re: walmart carpet
I dont know what your budget is, madaca, but you mite be further ahead to get one of the original rubber floor matts that cover everything. My .02...
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Re: walmart carpet
I too was on a budget in high school. thats why I tried the cheap carpet, and as stated above it basically turned into shag carpet making it impossible to vacuum. I finally saved up enough for a kit, which was way better but Im thinking of going the rubber floor mat route this time around.
Re: walmart carpet
You could also use the DIY bedliner, which has the added benefit of being waterproof.
63 Chevy short step |
Re: walmart carpet
I used Ozite carpeting in my 64 Suburban-one piece front to rear, including the firewall. This stuff stretches to fit all the bumps and grooves, and holds down well with spray adhesive. I put sound deadener and foil faced(both sides) pad down, then the carpet. There's an online store called "yourautotrim" that's based in Alabama, and they have a lot of different colors.
Re: walmart carpet
Thanks everyone. Some very good suggestions. I will look into the rubber mats and yourautotrim for the carpet as well. I will let you all know what I decide to go with later when I begin the project.
Re: walmart carpet
My sister just did some work on her Iroc over the winter, used that carpet from walmart for the whole floor. Worked OK.
1982 K10 SWB 1987 V20 - Sold - Doh! |
1962 C-10
Re: walmart carpet
I recently did my 73 with that cheap carpet. It came out okay. It will do. For $7 a roll you can't beat it. For some reason, the black seems a little more durable that other colors.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
Re: walmart carpet
Find a carpet business and buy some remnants. You would be surprised at how cheap they will let the small pieces go for.
1961 GMC Suburban Custom 1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD) 1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746 1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD) 1951 Plymouth leadsled project 2005 Corvette conv. Procharged 1969 Corvette stingray 2006 Cadillac XLR-V 1950 Oldsmobile 98 custom project |
