06-20-2009, 10:37 PM | #1 |
Resident Curmudgeon
402BB PS Pressure hose help
I need the PS pressure hose for a 72 2wd 402 BB truck. Anybody have a part # I can give NAPA to cross reference or a source for this? A couple of years ago I got one no problem, now it seems not to exist.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
06-20-2009, 11:25 PM | #2 |
Re: 402BB PS Pressure hose help
If looking for a direct stock appearing replacement to my knowledge there is not one in the correct configuration (long metal tube that follows the frame) you may try advance or some other if not want "correct"- if you want the right hose Pickemup is the only one that has the correct piece reproduced.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
06-20-2009, 11:30 PM | #3 |
its all about the +6 inches
while not anwering the question, i CAN say the one from LMC is lame. Real thin metal, needing a lot of tweaking, and I doubt it'll last long. (72 402)
06-21-2009, 08:05 AM | #4 |
A local Industrial hydraulic shop can build one for you. They would need the old one for a reference.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! Last edited by RustyParts; 06-21-2009 at 08:06 AM. |
06-22-2009, 07:36 PM | #5 |
425hp409
Napa has two hoses listed for the 72 BB. NPS 71634 and NPS 71531. I don't know which one is correct as they both show the same ends in one description but show one has a male and one a female pressure port. I would get both to see which one would work for your truck.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
06-22-2009, 08:24 PM | #6 |
i never could find one that i liked so like they said couple post before.. i took my old line to a hydralic shop and they just put on a new rubber part.. used the same hard line.. cost $33 but then i knew it wasnt no junk
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
06-22-2009, 08:43 PM | #7 |
Moderator
The ones that Napa and other parts stores have are incorrect. A hose shop is the way to go to have one made up.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-24-2009, 02:18 AM | #8 |
i got stainless steel one from frank (pickupman.) http://67-72chevytrucks.com/vboard/s...d.php?t=311917
-jake
67 short fleet 71 blazer 4x4 72 blazer 2wd 76 gmc sierra 3/4t 4x4 62 bel air 01 blazer extreme member 11,943! |
