Old 06-21-2009, 12:24 AM   #1
spaseghost
certified tard
spaseghost's Avatar
power window & locks, speedo, and fuel gauge questions... sorry
okay, so i got the ok to spend all day tomorrow on my truck, yay me!!! so i gots me some questions.
1) Power windows - aftermarket kit, or what?
2) Power Locks - Keyless entry kit, or what?
3) Speedo - 275/50s, th400, 2.73 gears (from the rpo codes), needle dances like a gay irishman... new cable, or tranny speedo gear and cable? i always drive 5 - 10 mph over...bb powah
4) Fuel Gauge - damn thing dances worse than my speedo!!! the guy put in a new tank right before i got it, so i hope he replaced the sending unit... but i dont think he did, cause of the dancing. is that the problem/fix?
i wont answer anything unless somebody needs more info to answer me. im cleared from the boss to have all day father's day to work on the damn thing, so thats what im gonna do.
spaseghost is offline   Reply With Quote
Old 06-21-2009, 12:40 AM   #2
79Silv4x4
Workaholic
79Silv4x4's Avatar
Re: power window & locks, speedo, and fuel gauge questions... sorry
Good luck
1979 K-10 Silverado (work in progress)
1991 V1500 Subruban
1999 Suburban LT 4x4
2006 Suburban LTZ (daily driver)
79Silv4x4 is offline   Reply With Quote
Old 06-21-2009, 01:00 AM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
1] after market
2] key less entry only if wiring is good to start with
3]unhook the spedo and get a GPS
4]sounds like the sending unit or maybe it could be the wiring connector on the sending unit
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 06-21-2009, 02:34 AM   #4
spaseghost
certified tard
spaseghost's Avatar
manual locks... oh well
im fairly confident its the stock 85 sending unit just from looking at it. ill clean up as much as i can.
thanks. ill put up pics of the underside tomorrow, some time. gonna set the timing and dial in the carb too.
Old 06-21-2009, 04:32 AM   #5
Prong
Have you lubed the speedo cable? If not, do that. If it doesn't improve, replace the cable. I replaced a cable in one of mine and it only ran $20.
Prong is offline   Reply With Quote
Old 06-21-2009, 12:53 PM   #6
spaseghost
certified tard
spaseghost's Avatar
i sprayed some wd 40 in it behind the gauge, and tightened it up at the tranny. better, but not perfect, but it only cost an hour of my time. thanks.
Old 06-21-2009, 03:09 PM   #7
Prong
Try white lithium grease, or the speedo shop uses wheel bearing grease. If you use the wheel bearing grease, you just want a light coating all the way down the cable, except for a few inches at the speedo head end.
Old 06-22-2009, 11:44 AM   #8
85Bowtie
85Bowtie's Avatar
I thought you used graphite on speedo cables?
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 06-22-2009, 04:04 PM   #9
Prong
I used to until I had a a new cable made up at the speedo shop. I had him show me what he used and how he applied it. He just uses a light film (emphasis on light film)of wheel bearing grease on the cable and it works like a charm.
