Need gauge wiring help
Can anybody tell me which posts are +, which are gnd and which are sender on a stock 84 Chevy truck gauge cluster? The guy I got the truck from got the bright idea to do away with the cicuit board and do point to point wiring on the gauges but wasn't sure which is which?
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: Need gauge wiring help
Hope this helps you out.
This is as you are looking at the backside of the cluster assembly. Oil pressure; Sender is to the left Positive to the right Ground is bottom center Temp gauge; Sender is to the Right Positive to the left Ground center top Voltage; Positive Left Ground Top Fuel gauge; Sender left positive Right ground center
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Yes!! That is exactly what I needed and I can't thank you enough for the info. I couldn't find it anywhere and googled it for days.
