Active Member
![]() Join Date: Dec 2004
Steering Wander. Play in steering box?
My truck really wanders bad both ways at 45mph. Should there be this much play in my steering box? I looked at another truck and it seemed to be the same way. Hopefully the video works. thanks
looks like u just have to click the photo to watch the video.
_________________________________ 1972 Chevy SWB 4x4 350 4speed |
![]() Join Date: Dec 2008
Re: Steering Wander. Play in steering box?
Please do not drive that untill you get a rebuilt steering box, and no it should not have any play like that. If that shaft moves your tires should also.
its all about the +6 inches
there is supposed to be play in the gear box, but that is possibly 50% more than designed, but is also pretty typical.
Non power assist usually have twice that, those boxes are always worn out bad. |
You can also adjust them instead of getting them overhauled. I've had TONS of play taken out just by having someone with more of a brain that I have get in there and adjust the worm gear. Try that first. If the play can't be adjusted out, then it's time to get it rebuilt.
I remember reading about adjusting a place on top of the gear box for excessive play. Believe I read that in the overhaul manual..I wouldn't drive that till you addressed that.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
i have plenty of play in mine, maybe not as much as yours maybe as much. mine does not wander too much.
