06-22-2009, 07:21 AM | #1 |
suspension help needed
I have a 77 stepside. I purchased it already lowered. I measured the height from ground to edge of fenders and the front is 28" and the rear is 27 1/2". I am not sure how the guy dropped it 4" in front. It does have new springs in it. The rear has 7 leafs plus a overload spring and it has a flip kit on it. I am wondering if I remove the overload spring would it raise the rear the 1/2" to bring it up to 28" so the truck will sit level?
06-22-2009, 08:11 AM | #2 |
Re: suspension help needed
if you have a flip, it would bring it up the thickness of the overload.. one could imagine anyway... just drop the front more
06-22-2009, 11:20 AM | #3 |
Happy to be here
If the overlaod spring you refer to is a 3/4" leaf at the bottom of the pack removing it will not help. If anything it might be holding your truck up a bit. If you remove it this may allow your spring pack to sag some and lower it even more.
Does it have a lowering shackle on it?
06-22-2009, 11:33 AM | #4 |
6.0 powered square
they do make lifting shackles, this would be the easiest way to get 1/2 back
http://summitracing.com/parts/BEL-6404/
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
06-22-2009, 12:47 PM | #5 |
I just want it to sit level. I am not sure how they came up with 4" drop in front. Most of the kits I have seen have 2 1/2" spindle drop with 1 or 2" Springs. The rear is at 27 1/2" That would mean a 6 1/2 drop over stock. Is that normal of a flip kit? It appears to have stock rear shocks on it with no extenders and no C notch.
06-22-2009, 12:56 PM | #6 |
Gettin It One Pice At A Time
Taller tires!!!! lol I don't know, good luck!
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby Last edited by 79gmcc15; 06-22-2009 at 12:56 PM. |
06-22-2009, 02:42 PM | #7 |
6.0 powered square
what's your tire size
06-22-2009, 03:48 PM | #8 |
I will have to check when I get home.
06-22-2009, 05:01 PM | #9 |
depends on if the springs are old and saggy. I mean on average it usually just drops whatever the thickness of your axle and whatever brackets are used
06-22-2009, 08:54 PM | #10 |
p27560r15
