Old 06-22-2009, 10:48 AM   #1
americanmusc1e
americanmusc1e's Avatar
Question factory '70 alternator belt
OK my truck rolled the old alternator belt. I went to Autozone and bought another one. I had to stretch the belt on to get it to fit, then I adjusted the alternator all the way out to tighten it. The new belt rolled too.
why does my alternator not seem to have enough adjustment?????????
does anyone else have this problem??????
pictures to follow
thanks in advance,
Josh
EDIT: the truck has vortec heads now, but I had the same problem with the old heads
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 06-22-2009, 11:07 AM   #2
americanmusc1e
Re: factory '70 alternator belt
-- Josh
Old 06-22-2009, 02:13 PM   #3
nightmare
nightmare's Avatar
it seems as if there is an alignment issue. try posting a pic from the drivers side showing the belt and all the pulleys it goes around.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 06-22-2009, 03:08 PM   #4
Gray Ghost
Gray Ghost's Avatar
Those newer belts are really not made right to fit these old pulleys. Mine sang like a siren when the throttle was down until I found an older one without the 'teeth'. Try Napa for the older style belt and see if that helps.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 06-22-2009, 03:20 PM   #5
vectorit
What?
vectorit's Avatar
If it were me...
I'd pitch that lower bracket. (Looks like a BBC bracket).
It's placing your alternator to low, and the upper bracket is over extended.
I'd then set up the correct bracketry for your year, and being that you have the holes in the cyl. heads that's no problem.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-22-2009, 04:04 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
he has the right brackets.
However, I hope that's the old belt... since it is on upside down??
Old 06-22-2009, 04:07 PM   #7
Wrenchbender Ret
Make sure the alignment is correct. Sometimes you need to shim it forward a little. Then get a shorter belt. A good parts man tell the length of the belt by the part no. Dont get it much shorter, it seems like a little goes a long way. About 1-2 in.
Wrenchbender Ret is offline   Reply With Quote
Old 06-22-2009, 05:28 PM   #8
El Jay
Gone to greener pastures
Maybe it's a 'gator back.
Take the belt off and stand beside the truck & then give the alternator a "good" spin by hand & watch for run out (pulley wobble).
As I was standing at the side of I-5 last year coming home from camping & waiting for "the hook", I did just that.
Said, "Dang, that has got a bunch of run out."
Changed the alternator (also converted to internal regulator at the same time) and no problems in the last 10 months.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 06-22-2009, 06:54 PM   #9
71 super
71 super's Avatar
Check that one of your other pulleys is no bent in some way. I had a motor several years ago that had no problems then one day could not keep alt belt on it, turns out the crank pulley had gotten bent some how and it was throwing the belt off. check it out if it is not a big deal to fix I used a pair of pliars to bend it back out and no problems.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 06-23-2009, 11:35 AM   #10
americanmusc1e
NO, thats the new belt, I put it on right side up, then I tightened it up. When I got home, it was like this!!
I guess I'll get a smaller belt like I did last time, then I'll look for a serpentine setup for the truck!!!
-- Josh
Old 06-23-2009, 04:27 PM   #11
Longhorn Man
wow.
Old 06-23-2009, 06:43 PM   #12
Sammy
Never seen one twist it inside out before without throwing it off.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 06-23-2009, 08:06 PM   #13
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Originally Posted by vectorit View Post
If it were me...
I have a 70 also and my alt is hung by a piece of coat hanger and I can't tight'n it any more with out twisting the junk hanger up...my roblem is NO HOLES in the heads fro the stock bracket any Ideas.....oh and i have headers too
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 06-24-2009, 08:18 AM   #14
drmiller1
I had a similar issue on my 69. Advanced Auto Parts has a belt-
Drive Rite # 51015- It's made by Dayco. This belt stays.
Nothing better than an old truck...
76 C-10 Silverado
92 Silverado Z71
drmiller1 is offline   Reply With Quote
