01-04-2003, 01:29 AM | #1 |
Newer 6 lug wheels ?
My nephew has a set of wheels and tires off an '01 Tahoe, which I think are 6 lug wheels. Anyone know what the pattern is on those, and if they'll work on the original 6 lug pattern on a '70?
Thanks, Scott
------------------------------------------------ I say it's only money, my wife says it's only a truck.... '71 C10 Deluxe, factory ac, ps, pb, should be done by 2102 Longmont, CO husker95@hotmail.com |
01-04-2003, 01:34 AM | #2 |
urban fourwheelin
I don't think they will work I believe they are metric
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
01-04-2003, 01:35 AM | #3 |
The bolt pattern should be the same but the off set on the wheels makes them set too far in on the truck, I think they may look funny.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
01-04-2003, 03:40 AM | #4 |
Pronounced "Pew-al-up"
The center hub diameter is too small, I tried it myself. It wont fit over the hub...
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
01-04-2003, 03:53 AM | #5 |
Recovering Truck Driver
A friend of mine put a set on a 74 K-10, they had to machine out the hole in the center to accomodate the larger hub, but the bolt pattern worked fine.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
01-04-2003, 10:02 AM | #6 |
To summarize, the bolt circle is the same 6 on 5 1/2" as ALL 6 lug GM, the center hole is too small, and the backspacing is about 5 inches vs. the 3 1/2" that was used on '87 and older trucks which makes the wheels/tires sit further under the truck.
Tim |
01-04-2003, 11:20 AM | #7 |
Thanks everyone! This board is the greatest, and I wish I had more time to be here.
Scott
