Old 06-22-2009, 02:37 PM   #1
Manuel Raptor
Manuel Raptor's Avatar
72 K5 Axles
I was wondering if someone can educate me on what axles came stock with the K5. Also how can I ID my front axle its an 8 lug.
72 K5 CST
Manuel Raptor is offline   Reply With Quote
Old 06-22-2009, 02:59 PM   #2
72truckman
72truckman's Avatar
Re: 72 K5 Axles
If you front is an 8 lug, it could be a rare HD Dana 44 but is more likely a Dana 60. I believe the 44 has a casting somewhere near the pinion that says "44", and i think the most notable difference between the two is that a D60 is a full floating front axle.
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
http://67-72chevytrucks.com/vboard/s...d.php?t=291482
****SOLD!!!!!**** 1965 GMC 4X4
http://67-72chevytrucks.com/vboard/s...d.php?t=294727
72truckman is offline   Reply With Quote
Old 06-22-2009, 03:14 PM   #3
Manuel Raptor
Re: 72 K5 Axles
It has no casting of "44". It is also a 10 bolt.
72 K5 CST
Old 06-22-2009, 03:19 PM   #4
Burt4x4
Burt4x4's Avatar
Re: 72 K5 Axles
72K5 came with Dana44 front and GM 12bolt rear.
Take a pic and post it up = Axel ID
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 06-22-2009, 03:28 PM   #5
Manuel Raptor
Re: 72 K5 Axles
Wfe took the camera. As soon as she gets home I will post a pic. I did find a casting on it 458856 also there is a letter N over that number.
72 K5 CST
Old 06-22-2009, 10:04 PM   #6
Manuel Raptor
Re: 72 K5 Axles
Ok I have pictures now. Hope they help.
72 K5 CST
Old 06-23-2009, 02:29 AM   #7
72truckman
72truckman's Avatar
Re: 72 K5 Axles
That is not a D44 or a D60. Looks like just a common junkyard GM 10 bolt. Someone who knows more about axles will hopefully chime in and be able to tell you exactly what you have.
Work in Progress
Old 06-23-2009, 05:53 AM   #8
Blazer1970
Blazer1970's Avatar
Re: 72 K5 Axles
Yup, corp. 10 bolt front axle.
Blazer1970 is offline   Reply With Quote
Old 06-23-2009, 10:58 AM   #9
Burt4x4
Burt4x4's Avatar
Re: 72 K5 Axles
Looks like someone swapped in a GM10bolt
Most treat GM 10bolt (not sure what year they came out?) and Dana44 the same, as far as durabillity goes.
Old 06-24-2009, 11:26 AM   #10
Manuel Raptor
Re: 72 K5 Axles
I wanted to say thank you to everyone with your help on this axle.
72 K5 CST
Old 06-27-2009, 05:54 AM   #11
vtblazer
vtblazer's Avatar
Re: 72 K5 Axles
You'll find that this board nothing if not helpful.
vtblazer is offline   Reply With Quote
