Old 06-22-2009, 03:10 PM   #1
vegaschevy
A couple of frame, shock and bushing questions
I bought this rolling chassis at this point.
Are these plates OEM? are they something that was added and if so why?
Also take a look at these bushings. They appear to go in from one side only like a newer i cannot remember the name but they are like NItrate or some kind of injected bushing on newer cars. Does everything look right assembled the way it is?
Also lower shock mounts, the uppers are on the cross member, im guessing the lowers are something I can purchase that go on the bottom of the u bolts?
vegaschevy is offline   Reply With Quote
Old 06-22-2009, 03:17 PM   #2
bw4sale
bw4sale's Avatar
Re: A couple of frame, shock and bushing questions
Yes, those plates are factory. The rivets were probably drilled out and they were taken off to address rust issues in between the plates and the frame. I am needing to do this right now to mine. Hope this helps.
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 06-22-2009, 03:20 PM   #3
vegaschevy
Thank you sir. Ill have to take the bolts out that are on it as they are not long enough in a couple holes and WAY to long in the one hole. I am pretty picky about correct length bolts
Old 06-22-2009, 09:33 PM   #4
my67chevytruck
Under Construction
my67chevytruck's Avatar
The trailing arm bushing looks correct, they only press in from one side, with those aftermarket arms, you may have to shim it some if needed. I have attached some pics of the lower shock mounts, I have these available, as we went with ECE shock relocators.
Heath
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-22-2009, 10:24 PM   #5
vegaschevy
What are the ECE shock re locators?
These rear arms are not factory? what is the difference?
Old 06-22-2009, 10:26 PM   #6
vegaschevy
Looks like i just found the difference, the factory arms are stamped and welded in the center and not boxed
Old 06-22-2009, 10:29 PM   #7
my67chevytruck
Under Construction
Shock relocators change the shock angle on lowered trucks 4" or lower
I will attach a pic of some OEM trailing arms they resemble an I beam. in the attached pic, you can see the shock mount on the passenger side.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
