Frame coating while in the mockup stage
I am getting ready the start the frame for my Blazer project. I plan to convert a 4X4 chassis to 2wd. I am going with a Dropmember C4 static drop (coilover) suspension in the front and a triangulated 4 link in the rear with c notch and coilovers. So, I will need to do alot of welding on the frame. For now, I am going to have to do most of this work outside. The plan is to sandblast before any work starts. What should I coat the chassis with while I'm in this process? I plan to take my time, so it could be in mockup for 6 month to a year (and maybe longer if life happens). After the mockup is done, I will go to a chassis paint or POR15. I don't mind having to blast again after mockup as I have my own blasting setup.
Chad Last edited by 14U2NV; 06-22-2009 at 03:43 PM. |
The LuvShack Garage
Re: Frame coating while in the mockup stage
I didn't blast and powder coat mine till I was done messing with the frame.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
![]() Join Date: May 2009
I think a coat of weld thru primer (zinc) would do.
Good luck with your project!
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
Yeah, I def wouldn't put the final finsh on it until I was certain I was done welding and putting holes in it. But due to the fact it will be out in the weather for an extended time, I just wanted to make sure I did not harm the frame any.
Does weldable primer allow moisture through like regular primer does? Chad |
It would protect by forming a coat of zinc oxide over the steel. I have a '53 pickup cab here that I coated the firewall with weld thru primer about a year ago and it sat outside in rainy weather for a while, still no rust forming.
Cool, I'll be looking for some zinc primer soon. Thanks for the info.
Chad |
