i bought a new door and now have to transfer all door components to the fresh door. anyone know the smothest order to reinstall the vent window and regular window which is first thanks a million this is my first post but know all the good info on these trucks are here!
Its a Truck Thing......
Re: help with window install 70 c10
Ive always had luck putting in the vent first, leave it loose then put in the window.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
its all about the +6 inches
i suspect this was being asked about a truck, even if it is a burb, the steps are the same, and you'll get a million times more traffic on the truck forum. So I'm moving it to the truck forum instead of the burb one.
Welcome to the boards from central ohio! |
![]() Join Date: Jan 2008
Put the window in first,roll it down,slide the window all the way towards the latch end of the door, remove the back track on the inside of the door, put the vent in,you will probably have to twist it around a bit, put it in place with a couple of screws, roll the window up while pushing it forward in the vent track, re-install the back track thru the door, tighten all the rest of the screws.Good luck
I agree with bigsnookmaster. That is how I did it. There is a good write up in the FAQ's on this as well. It can take time if you have never done it before but just be patient with it.
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs http://67-72chevytrucks.com/vboard/s...d.php?t=272458 2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds |
