06-22-2009, 06:53 PM | #1 |
Slugish
Wheel spacer question
Ihave 17x9.5 tt 2's on the rear of my lowered 84 with 275 x 50 rubber . Iwas told when Ibought them Ishould go with 5.5 backspacing , which Idid .
Ihave never been completely sastisfied because ICOULD GO AT LEAST 1 IN WIDER ON BOTH SIDES. Ihave also M T street et's Iput on occasionally & iLIKE THE WAY THEY LOOK BETTER -15 IN. WITH 4.5 BACKSPACING . Enough for that , question is : 1. do any of you run spacers 2. are they safe 3. one of you some time back gave me a web site for a guy who makes them . Does anyone know this site > I lost it should have got 4.5 bs on the get go , but oh well thanks in advance for your help |
06-22-2009, 07:31 PM | #2 |
yeller
Re: Wheel spacer question
I run spacers on my 77, no issues at all. I got mine from a seller named cjbargains on eBay. Great seller, cheapest I have found. $59 per pair. Includes all lug nuts, they are real nice.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
06-22-2009, 08:00 PM | #3 |
I have the same exact rims with a 275/40 MT et drag radial. I put a 1.75" spacer on mine and the tires sit about .5" from the inner fender. I of course have a stepside though.
I have raced my truck numerous times with the spacers and have plenty of miles on them. I bought them from a place that makes them for 4x4 trucks that off-road and run huge amounts of torque. They were around $100. If your interested I can dig around for the receipt.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time Last edited by Wild83C10; 06-22-2009 at 08:01 PM. |
06-22-2009, 08:03 PM | #4 |
yeller
I would like to know the company.
Was that price per pair?
06-22-2009, 09:42 PM | #5 |
Performance wheel and tire. They were $85 each, made of Billet 6061-T6 Al. Included studs and nuts.
http://www.performancewheel.com/ Like I said before, the off-road guys recommended them. If they work for them they should certainly work for street use.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
06-22-2009, 10:55 PM | #6 |
I run an adapter. Just put them on today... so far so good.. but there is a vibration around 50mph in the rear. I'm going to retorque them in 50 miles and again at 3000 miles.
06-23-2009, 12:25 AM | #7 |
Resistance is Futile
Just happened to see this thread......I used 4 on an S10 to correct backspacing 1''. I had 30k on them with no issues....and I hauled all my flagstone in that truck lowered with overload bags in the back. I wouldn't hesitate to use them again....just follow the torque instructions. Its like bolting on heads.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
06-23-2009, 03:07 PM | #8 |
Slugish
Thanks to all of you for your response.
Ithink I will look at performance wheel . Iactually thought about selling my 17 X 9.5 tt2's with 5.5 bs. & buy a set of the same thing with 4.5 bs . Dont really know what Icould get for mine , & WHAT NEW ONES COST NOW .What I have heard is that they have gone up a lot since I BOUGHT MINE APPROX 5 yr's ago . Iguess Ishould ck. the price on new ones > estimate what Imight get for mine & see if the difference would be a great deal more than 200.00( price for 2 spaceres) What do yall think ? |
06-23-2009, 03:45 PM | #9 |
I run them on my burban with no issues...
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
06-23-2009, 05:21 PM | #10 |
Gearhead
I have a pair front (1") and rear (1-1/4") from Performance Wheel & Tire forever and never had any issues (72' C10)
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 Last edited by 6772owner; 06-23-2009 at 05:22 PM. Reason: text |
06-24-2009, 11:25 AM | #11 |
First, I think if you are gonna run a 1" spacer (not an adapter), then you should probably put longer lug studs in the axles. I would. So, factor that into cost. And the trouble of removing axles, and if you are as lucky as I am, then that retaining pin in the rear is gonna break like mine always do in almost every gm rearend that I have everworked on.
Second, if you aren't too much out of pocket--I would buy new wheels. Then you can get a deeper, wider wheel that really want.
Joseph 87 Turbo Buick 92 5.0 Mustang coupe 87 GMC Sierra SWB 82 Chevy K5 Blazer 2wd |
06-24-2009, 11:32 AM | #12 |
06-24-2009, 11:51 AM | #13 | |
yeller
You only need to put longer studs in when using a spacer less than 1" thick. I am telling you guys, you can get cheaper spacers, same quality as the more expensive ones (I have used both), from cjbargains on ebay. The only catch, he only sells 1" and 1.5"
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 06-24-2009 at 11:51 AM. |
06-24-2009, 11:52 AM | #14 |
yeller
Fred is a super nice guy, great service too!
