Old 06-22-2009, 07:22 PM   #1
cwilkie
Chance
cwilkie's Avatar
Heat Resistor
What does a heat resistor do? My truck continues to blow heat even though the fan is off and the entry door on the heater box is closed. Does the heat resistor have anything to do with this?
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 06-22-2009, 07:32 PM   #2
JimKshortstep4x4
Re: Heat Resistor
I suspect that your problem is caused by the hot water flowing through the heater core and air leakage by the heater door makes the heater put out hot air.
A fix that works pretty well is to put a shut off valve in the 5/8" heater hose so the water flow can be turned off.
If you have AC then the vacuum water shut off valve may be a problem.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-22-2009, 09:07 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Heat Resistor
the resistor controls the fan speeds.
Old 06-22-2009, 09:28 PM   #4
fixit-p
fixit-p's Avatar
Re: Heat Resistor
Are you sure the heater box door is closed, on my 69 the flap which diverts either cold air or hot just moves freely on its shaft so the linkage moves but the flap stays put.
fixit-p is offline   Reply With Quote
