06-22-2009, 08:58 PM | #1 |
Rear Coil Springs
Will a 3/4 ton rear coil spring fit in a 1/2 ton truck?
I put a set of CPP 4" dropped springs in my 1/2 ton and they are way to "soggy". I'm thinking about putting a 3/4 ton 4" dropped spring in to make it stiff. I had a set of heavy duty standard height springs in there before the drop and the coil material was massive in comparison to the CPP stuff. I still have the heavy duty BB stock height springs in the front with dropped spindles. |
06-23-2009, 01:42 AM | #2 |
Re: Rear Coil Springs
Was this such a stupid question that no one wants to answer?
I don't really see why it wouldn't work but since I'm not real sure I thought I would ask before I spent another 100 bucks on something that won't work. |
06-23-2009, 08:28 AM | #3 |
I would just call and ask, I believe the springs will fit but I would make sure they are indeed stiffer or larger diameter wire. If they are a drop spring they may think you wont be hauling anything so they are indeed the same parts?
good luck Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
