06-22-2009, 09:35 PM | #1 |
firing order on a 402 bb
what is firing order..
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
06-22-2009, 09:37 PM | #2 |
Roadtrip!
Re: firing order on a 402 bb
1 8 4 3 6 5 7 2
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
06-22-2009, 09:44 PM | #3 |
My Carbon Footprint
How is it going? Get the dist in yet? You are asking about firing order so that is a good sign. You are going to want to have a light on that when you first fire it. Remember, counter clockwise is advance. When you get everything set up, you want to turn the cap so the rotor is just a little before the #1 so you have a little advance. Make sure and plug the vac from the carb when you set your timing. Big blocks like advance for the street. I run mine at 18 degrees and another 18 of mechanical. Also make sure and look the vacuum line back up to the carb.
06-22-2009, 11:58 PM | #4 |
i have to put the ends on my plug wires.. and put my new plugs in.. and then hand crank the motor to put the mark at 0.. thats it..
06-23-2009, 12:06 AM | #5 |
My Carbon Footprint
do it backwards. It's harder to "bump" the motor with the plugs in because of compression. If you to it the opposite, you can look into the cylinder through the plug hole to see the top of your piston. This way you will know you are at true TDC.
