Rattling Brake Calipers Up Front
So my calipers are rattling. When I apply the brakes, they stop. I took the wheel off and it looks like the studs that hold them on are too small.. it rattles on them. OR could it be that I'm missing some grommets or bushings? Anyone know?
#2 | |
Re: Rattling Brake Calipers Up Front
Another common issue is the pads themselves 'shifting' within the caliper when the brakes are compressed. This typically requires bending the tabs on the pads in a little tighter so there's an interference fit when installing them in the calipers.
Thank you!
Now any idea where I would find the o-ring style seals? Would this be an auto part store item hopefully? I'll try the tab adj too when they go back on. |
You can find the caliper seals(bushings) at Carquest in caliper rebuild kits. I'm sure you can find it other part stores too. Like Scoti said check the pads for the rattle and tighten the tabs near the hat of the rotor.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
You all were right.. O'Reillys make a rebuild kit but I think I'm going to replace the whole caliper since they are only $11 each!
you don't need a rebuild kit....most parts stores sell the hardware kits....
here is the hardware kit from Autozone. $4.99 for both front calipers autozone linky
18 Till I Die
I think your old GM caliper would be better than a new $11 one?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
#8 | |
The $11 caliper come assembled with the bolts and everything.. I can't believe that cost, but I have always gotten good parts from O'Reillys so I trust that they are decent at least. |
#9 | |
If they will indeed tighten up the calipers in your situation, the rebuild kits are a much quicker/easier solution. Swapping the entire caliper will require bleeding....not you, the fluid.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
