06-22-2009, 11:17 PM | #1 |
resident oilfield trash
Idea
I have a big ugly hole in my floor. I have a 67 Chevrolet swb. I am thinking about cutting my floor out for a Big block hump. Can anyone think of a reason I shouldnt do this
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
06-23-2009, 10:02 AM | #2 |
Re: Idea
Question is do you NEED TO? Why not just patch the hole?
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
06-23-2009, 10:16 AM | #3 |
Re: Idea
If you have the hump to cover the cutout IC no problem. Make sure the hump is the correct one for the transmission your going to use..ie..no holes in the hump cover if remaining a column shift.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
06-23-2009, 10:53 AM | #4 |
Old Skool Club
Re: Idea
At what point do holes in the floor become attractive? If it was mine, I'd (1) patch it with sheet metal or other suitable material that would then be covered by carpet or proper floor mat, or (2) insert a shifter into said hole that would them be used to operate the transmission. If the said hole is not in the right place for that to occur, then use your imagination and cover the wrong hole, with the proper material (see #1).
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
06-23-2009, 11:01 AM | #5 |
The Older Generation
Re: Idea
I have a 454 and TH400 in the White '67 with a low hump. Just get the piece you need to patch the floor out of a donor or junk yard truck and weld it in.... LockDoc
