Old 06-23-2009, 12:15 AM   #1
mas09ts
mas09ts's Avatar
Leaf to Coil Swap
Anyone got a how to or info on how to do this, any pics?
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 06-23-2009, 08:29 AM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Leaf to Coil Swap
I have seen some leaf spring trucks that had the trailing arm crossmember in place. Is this the case on your truck?
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-23-2009, 09:08 AM   #3
lofly'a
lofly'a's Avatar
i'll take a stab since i will be swapping my 71 gmc over soon, but with air ride. i know that on my swb the trailing arm crossmember is there, but the brackets for the trailing arms are not. also, the the crossmember that the rear shocks are attached to on the leaf suspension is different. then theres the panhard bar, brackets, and hardware that have to be addressed. the rearend does not have the cast in mount (hole) for the panhard bar, but that is'nt a show stopper unless you want it stock looking. early classic or CPP can help with that issue. at the least you'll need a panhard setup, rearend with lower shock mounts, trailing arms and brackets, and the coils, bags or whatever...... this is what i know about swb trucks, i have no idea what you have if your is a lwb.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 06-23-2009, 11:09 AM   #4
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Other than swapping parts from a coil truck (like mentioned above), one of the biggest things to address are the coil springs themselves.
The frame rails on the leaf truck are practically straight/parallel over the axle, where the coil spring frame bends out. The coil springs attach to the underside of the frame. (See pic) So when converting a leaf truck to coils, a bracket needs to be made to bolt/weld to the outside of the frame to give the coils something to attach to. I have seen these for sale (don't remember where), but they would be super easy to fab.
Use ECE's super track bar. It mounts to the frame on the drivers side (will need the OEM bracket, or fab one) then to the right side trailing arm.
You will need the trailing arms saddles off of a coil spring rearend. Or just find a complete coil spring rear end.
Shock crossmember (upper), shock brackets off of a coil rearend (lower).
Front trailing arm brackets.
LWB, SWB, it's all the same back there.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-23-2009, 12:55 PM   #5
lofly'a
lofly'a's Avatar
thanks Glock i forgot about the upper coil mounts. i went back and looked at the frames and compared the 71 gmc to my 72 chevrolet with coils and the frames are exactly the same.
Old 06-23-2009, 05:29 PM   #6
mas09ts
mas09ts's Avatar
It has these holes so....
Mitch
22yrs. Young
Old 06-23-2009, 05:33 PM   #7
glock35ipsc
Compare your pic to mine, and you can see where the trailing arm brackets go. The holes closer to the hole for the driveshaft are for the carrier bearing bracket to mount to.
Bob
Old 06-23-2009, 07:27 PM   #8
SCOTI
SCOTI's Avatar
I had both, a short leaf (67 GMC) & short coil (68 Chevy) rolling chassis side by side in my driveway @ the end of '07. My experience is the frame rails were the same on both trucks. The 'curve' where the springs mount is there for both & they do utilize different bracketry. The 'curve' is not there on 4x4's (frame is straighter as described above).
The leaf frame did have some structural 'beads' in the steel around the spring hanger areas that the coil frames don't have.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-23-2009, 09:36 PM   #9
mas09ts
mas09ts's Avatar
So what would i need if my crossmember will work?
Mitch
22yrs. Young
Old 06-23-2009, 09:42 PM   #10
powerbench
powerbench's Avatar
The frames are the same except for a few reinforcing dipples that are stamped right where the leafs supports go..I just finished doing this swap , and got a lot of help from everybody here.I found the best way was to do it with the box off , and have a coil truck handy for all the brackets you need...and for measuring all the bolt hole locations...i'll try to resize some pics of how mine came out.
powerbench is offline   Reply With Quote
Old 06-23-2009, 09:48 PM   #11
mas09ts
mas09ts's Avatar
thanks man pics would help
Mitch
22yrs. Young
Old 06-23-2009, 10:09 PM   #12
powerbench
powerbench's Avatar
i love pics so here i go..... Name:  frame  small 1.jpg
Name:  frame small 2.jpg
Name:  frame small 3.jpg
Old 06-23-2009, 10:12 PM   #13
powerbench
powerbench's Avatar
moreName:  frame small 4.jpg
Name:  frame small 6.jpg
Name:  frame smaller.jpg
Old 06-23-2009, 10:16 PM   #14
powerbench
powerbench's Avatar
hope i don't over load the server.... hope these help Name:  frame small 7.jpg
Name:  frame small 8.jpg
Old 06-23-2009, 10:24 PM   #15
mas09ts
mas09ts's Avatar
Now thats step by step great dude!! thanks
Mitch
22yrs. Young
Old 06-24-2009, 12:06 AM   #16
ERASER5
ERASER5's Avatar
And what are you guys doing with the old leaf springs? There are some people who do the exact opposite swap. Brackets, hangers and such are hard to come by. We do have a sale forum here. That's all I'm say'n.
(Mine was born with leaves)
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 06-24-2009, 08:53 AM   #17
glock35ipsc
Ah-ha, you got me! The only leaf trucks I have been looking at for reference are my two 4x4 frames out back. My 67 GMC 2wd was leaf, but I never paid it any attention. I wonder what the Blazers frames are like. I have a 72 and have been kicking around the idea of converting it to a 2wd.
powerbench - Great pics!!
Bob
Old 06-24-2009, 09:21 AM   #18
14U2NV
I parted a LWB GMC many years ago and it had leafs and the trailing arm crossmember sans the brackets. It does have the carrier bearing support bracket. My question is that I can see the two larger holes to the outside have the parking brake cables running through it, what are the other two holes of the same size for? I plan to run my exhaust through there on the blazer. I think I can get by with leaving the brake cable holes but not the other two.
Chad
14U2NV is offline   Reply With Quote
Old 06-24-2009, 09:27 AM   #19
glock35ipsc
Chad
Here is mine. This is the drivers side, from the rear. The lower left hole is for the e-brake cable. Don't know what the others are for, but I don't need them, and I haven't seen anything ran through the others on any of the other 67-72's I have/had.
Bob
Old 06-25-2009, 11:07 AM   #20
mas09ts
mas09ts's Avatar
So all i need are trailing arms, coil rearend, and crossmembers that i need? I think i can get a whole coil spring truck for about 200 bucks.
Mitch
22yrs. Young
