Old 06-23-2009, 03:37 AM   #1
hillytim69
Flexplate wobble!
Well I've run into a problem, I've posted a few times on my progress on my 75 Stepside, sm-465 to Th 350 swap. I put in a 383 turbo 350 combo with a new B&M 2000 converter and the Pioneer flexplate that came with my shortblock. I thought when I bolted the flexplate/converterbolts that there was too much distance between the two. What I've run into now is that it seems maybe the flexplate had to flex too much to reach the converter and now it is warped. I kept hearing a strange noise under there when running and found the flexplate noticeably wobbling. I should've figured this out before when I was trying to install my mini starter and found varying distances from starter gear to flexplate ring gear depending on engine position. So this really sucks. I think I may need to remove the tranny and put shims on the end of the crank before the flexplate. I've never had this happen before when bolting a motor and trans together. Do you guys think it may be due to the aftermarket Eagle crankshaft? Anyhow I really want to get it on the road asap so I can take my boy to the Car Craft Summer Nationals next month in a Chevy, not a Honda... Any ideas or experience on this problem? BTW I did get my shifter (Z-gate) installed.
hillytim69 is offline   Reply With Quote
Old 06-23-2009, 07:21 AM   #2
James McClure
One shot, one kill.
Re: Flexplate wobble!
DO NOT SHIM ANYTHING!!! There are only a few things that will cause this. Was the flex plate installed when you got the eng? It could have gotten bent in transit. Next, if you installed it did you put it on backwards? Any weights ect. should face the oil pan. Does the converter hub bottom out in the end of the crankshaft like it's supposed to? Clearence between the converter screw bosses and the flywheel should be "0" on the slightly raised areas on the flexplate facing the trans. Your going to have to drop the trans to check things out. With the way you describe this issue I think you should be prepaired to replace the flex plate again. Hope this helps, jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 06-23-2009, 10:36 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
depending on the flex plate you have ive seen them come bad from the manufacturer... JMc hit it on the head if it aint in backwards its prolly a defect
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 06-23-2009, 11:35 AM   #4
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Change it out before it kills someone!
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-23-2009, 12:46 PM   #5
silvereagle07
silvereagle07's Avatar
It's on backwards. Do you have any pics of it?
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 06-23-2009, 01:59 PM   #6
hillytim69
Flexplate was not mounted when i got it. Its a cheapie Pioneer FRA-104. Its definitely not on backwards, I checked that out a few times. The raised converter bosses and crank flange face out towards the rear. I will be taking it all apart to inspect. I could post pics but don't know how to post them up on here. I do seem to remember a gap between the converter and flexplate mounting bosses when I installed it so I think when I tightened the bolts it pulled the flexplate towards the converter, distorting it. How do I know for sure if the converter "snout" is seated completely in the crank? I believe it is. The converter looks to spin true but the flexplate is wobbling. Any pointers on how to go about posting pics up on here would be great and I'll take some and update as I go. I will be ordering a better SFI approved flexplate as well. Sucks to have to pull the trans but what can you do...
Old 06-23-2009, 06:40 PM   #7
LONGHAIR
If this is a stick to automatic conversion, it is possible that the pilot bearing is not allowing the torque convertor to slide into the crank properly.
If that is indeed the case, the flexplate is probably perminently "flexed" an in bent or even cracked.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-24-2009, 02:43 AM   #8
hillytim69
In this case I also changed engines to a 383 so this is a brand new crank, I should've mentioned that. i will be taking it all apart soon and will report what I find.
Old 06-24-2009, 05:15 AM   #9
James McClure
One shot, one kill.
hilly, I think Longhair is on to something. Check for a pilot bearing in the end of the crankshaft. The converter hub should drop into the end of the crank an inch or so. Leave the flex plate off and hold the converter up there and try to slide the hub in. It should disappear into the crank hole. Let us know, jim
Old 06-24-2009, 03:52 PM   #10
hillytim69
I was just out looking at it. The flexplates raised T.C. mounting bosses face the rear but the counterweight is on the front twds the engine does that matter? Shouldn't it be on the rear of the flexplate?
Old 06-24-2009, 08:03 PM   #11
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
is the weight touching the converter,just wondering
powerdriver 1958 is offline   Reply With Quote
Old 06-24-2009, 11:26 PM   #12
hillytim69
Well its gonna have to wait until the wknd now. Wife found some free clothesline poles on Craigslist so I got to dig them out and bust off some 50 yr old cement instead of working on my truck today...
Old 06-25-2009, 05:46 AM   #13
James McClure
One shot, one kill.
Hilly, Read my post above. The weights face forward towards the engine. You have it in right. The only thing left to cause this is the converter not engaging the end of the crank properly. Like longhair said above, look for a pilot bearing in the crank. If it has one, remove it and test fit the converter. The hub on the converter should drop right into the hole and disappear. jim
Old 06-26-2009, 04:14 PM   #14
hillytim69
Today before i leave to work i loosened the flexplate to converter bolts. There is around 3mm or .112 inch between the converter mounting bosses and the flexplate mounting bosses when the converter is fully seated in the trans. Otherwise the converter has to pull forward or the flexplate move rearward for the 2 to mate up. the flexplate is warped bad as well. Could the converter be seating too far into the trans or do I have a bad flexplate on there or what the heck?
Old 06-26-2009, 07:11 PM   #15
LONGHAIR
The converter should slide back and forth in the free space between "bottomed out" in the transmission and touching the back of the flexplate.....when un-bolted of course.
It still sounds to me like something is stopping the converter from moving foreward far enough....As stated before, I have seen the pilot bearing turn out to be exatly that in more then one case.
I have also seen guys try to use the old flywheel bolts when installing the flexplate....this does not work either. They are too long and will hit the back of the block.
Old 06-27-2009, 01:33 AM   #16
hillytim69
Hey Longhair, the converter does slide forward in the free space and touch the flexplate. Maybe this isn't the issue. And the engine is a 383 with a new Eagle crank so i don't think it would've had a pilot bearing. I just thought that the "free space" of 3mm seemed like it was excessive. Again, the converter will move back and forth through this free space area. Perhaps this is OK but the flexplate is really warped nevertheless. I rotated it a little at a time and checked the clearance between the starter gear and the flexplate ring gear and it is pretty bad.UPS delivered my new thicker SFI flexplate from Summit and new ARP T.C. bolts today. The tranny is coming off (dammit!). So do you think my "free space" area of 3mm or slightly less than 1/8" sounds normal? Also I did use stock GM flexplate to crank bolts with the starwashers but they just barely protrude through the crank on the other side. WOw I've been swapping Chevy engines/tranny's since I was 19 and never had this many problems. I hope i only have to move the tranny back a little ways to do the flexplate R&R. We'll see how my Harbor Freight scissor type tranny jack works... Thanks for all the help and I'll keep updating as I go!
Old 06-27-2009, 10:20 PM   #17
Wrecker55
Wrecker55's Avatar
Tim, I have the same problem on my LT1 383, was rattling so i knew the sound and tightened up torque conv bolts. fixed it right off, them a few weeks later same thing. So I go to tighten bolts again and notice there bottomed out on torque conv, stock 350 crank bolts were just a smidge to long and I didnt notice. So I got right length bolts installed and same noise, and holes were enlonged, so I figuer it's cracked now and need to replace with new flexplate. Hope this hels you out.....Tim
Wrecker55 is offline   Reply With Quote
Old 06-28-2009, 01:09 AM   #18
hillytim69
Well I had a good garage thrash session tonight. Got the trans moved back about 6 inches and got my new flexplate installed. Still have to button everything up but i do believe the old flexplate was the problem. I think the shop that balcnced the rotating assembly stamped a serial number on the flexplate and pounded on it hard enough to warp it. On the other side from where they stamped it, you can see indentations fron the crank flange which are actually indented enough to feel . Also the balance weight looks to be welded on by a deaf dumb and blind kid who should stick to shooting pinball. Overall the old flexplate looks to be of very poor quality compared to the new one. I'll never just assume a new part is good again because this has caused me a lot of extra work but I think I'm seeing the light at the end of the tunnel.
Old 06-28-2009, 09:00 AM   #19
LONGHAIR
That is one of my "rules"....just becasue it's new, doe NOT mean that it is any good. I try to double check the new parts first whenever something goes wrong. Assuming that a new part can't be the problem has bitten plenty of people.
Old 06-28-2009, 11:54 PM   #20
hillytim69
Bad news. After bolting up the tranny to the block I went underneath to put in the converter bolts. I installed 2 bolts losely and when i got to the last i can see that one of the mounting bosses of the flexplate nearly touches the converter. So 2 mounting bosses have about 1/8" gap and the 3rd has barely any gap. With unequal gaps there, obviously when I tighten the bolts the flexplate will have to stretch to meet converter on 2 of them. The builder the shortblock told me to tweak the flexplate with a prybar so the gaps are roughly equal so the converter pulls in evenly. I've never heard of such problems. I put on a new flexplate, torqued it evenly on the crank what the heck? What are the odds that the end of my crank is not true? It would have to be a lot to make it that far out of wack at the mounting boss. I'm getting frustrated now.
Old 06-29-2009, 01:19 AM   #21
hillytim69
I tweaked flexplate in the 1 spot to make it the same as the other 2 mounting bosses. I think it should be ok. Will check for runout later. Think I'm just getting a little paranoid now. Its just a hunk of iron right?
Old 06-29-2009, 07:28 AM   #22
CSGAS
optomistic ah-so
CSGAS's Avatar
Is your tranny case cracked?
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 06-29-2009, 02:21 PM   #23
hillytim69
Thumbs up Re: Flexplate wobble!
I mounted the starter an turned the flexplate/engine by hand while measuring the gap between flexplate and starter gear as i went. I'm getting about .090" on average all the way around with maybe .010-.015 max runout which i can live with. The clearance between ring gear and starter should be .075-.125 per the Skip White ebay ad on this mini starter i have so I think I've got it.
Old 06-30-2009, 03:33 PM   #24
hillytim69
I drove it today. the horrible noise under load is gone. I do still have this whistling sound coming from somewhere. Could it be the flexplate making this sound because I have no inspection cover? Other than that it seems good. I guess I'll keep trying to figure it out. Next step will be to run the engine with the torque converter bolts out to see if if goes away. Its not the accessory belt because I tried that already.
Old 06-30-2009, 04:28 PM   #25
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
Does it whistle all the time, driving, standing still at idle? I've owned more than one '77 that whistled when ever you drove it down the road. Always figured it was air running over or through one on the openings in the radiator support. Drove me crazy! One of the trucks was brand new. I installed a tube grille in it and it was slightly worse with it in, but never the less the whistle was there with either grille installed. God Bless, Terry
77 350 Shorty Wide is offline   Reply With Quote
