06-23-2009, 06:35 AM | #1 |
HEI in 1971 4X4
Hi Guys,
I was wondering if there would any clearence issuse using the Summit HEI dist.in a 1971 4x4 short bed.The motor is a 307.Thank You! |
06-23-2009, 09:07 AM | #2 |
Born Psycho
Re: HEI in 1971 4X4
if it's the same diameter as a standard GM HEI, it'll be real tight and probably hit if you're off roading. i personally run pertronix in mine and have had good luck with it.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
06-23-2009, 09:17 AM | #3 |
Re: HEI in 1971 4X4
I also run a pertronix, and also have had good luck with it. HEI will fit but like he said it is very tight.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
06-23-2009, 09:28 AM | #4 |
Re: HEI in 1971 4X4
Thanks guys,I'LL look into that!We put a HEI into my son's 69 chevelle and WOW what a difference.But like you guys said ,there isn't much room in the 4x4.
06-23-2009, 10:46 AM | #5 |
Post Whore
Re: HEI in 1971 4X4
If your body mounts are worn out probably will be issues. I put new body mounts in my K5 and a factory GM HEI in it and it was tight, but it did fit.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
06-24-2009, 10:06 PM | #6 |
Re: HEI in 1971 4X4
If you do I would go with a stock style HEI with no top cap over the plug wires. I would use a $50 skip white HEI and get new cab bushings if needed.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
06-25-2009, 06:26 AM | #7 |
Re: HEI in 1971 4X4
Thanks Mike! I checked out your project money pit,awesome truck,no way I can do all that work myself!
06-25-2009, 08:53 AM | #8 |
Re: HEI in 1971 4X4
yes you can... just learn from the board and take baby steps...
