4 speed question
What 4 speed was used in 1977 1/2 2wd Chevy trucks? Would it be a good performance transmission??
On a budget like Fred Sanford
Re: 4 speed question
Most likely it's a sm465. Not at all a performance oriented trans with it's granny low gear, definitely a big truck tranny.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
Anyone know where I can get the parts to convert my auto to muncie 4 speed.
It'd be alot cooler if you did
The linkage for the clutch is all the same, and Hurst makes a shifter for the "muncie in a truck". Other than that you'll need a slightly longer drive shaft yoke or you'll need to lengthen the drive shaft about an inch. Use the donor vehicle info when ordering the flywheel, clutch, etc.
*edit* Hit the junkyard for the pedals and z-bar. I forgot you said you were starting with an auto. Also when I did mine I got the clutch rod boot, springs, new pedal covers, new pedal bushings and all the other small stuff from the dealer. Last edited by smashingchuck; 06-23-2009 at 11:00 AM. |
You cannot lengthen a drive shaft, only shorten it. If the one you have is too short after the conversion, you need a new longer one. Depending on what auto you have now, the stock one should work. I think mine is a stock one piece DS from a th350 2wd truck. I've got a M21 muncie in mine. The stock crossmember can be reused, just drill new holes in the frame. Like said above, find a donor truck in the salvage yard and take EVERYTHING. Pretty easy swap once you have all the parts.
I have the TH350 in mine at the moment.
Depending on what you mean by "performance".......If you're going to power shift, I'd suggest getting a Muncie 4-speed. You can get the mechanical clutch linkage from the wrecking yard or go to LMC and get most of the parts new.
A T-56 is also a reasonable "performance" transmission. From the two I've seen in pickups, you'll have to change the trans mount, possibly modify the crossmember, change shifter location, modify the driveshaft and install a hydraulic clutch setup. |
That's what my truck had as well. I just went with a yoke that was about 1-1/2 inches longer.
Workaholic
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
I should rephrase.......The only way to add length to a drive shaft is to "re-tube" it, meaning you remove both weld yokes and install them on a new tube of the proper length. As cheap as new drive shafts are it's easier/cheaper to just measure and buy a new one.
