06-23-2009, 10:09 AM | #1 |
Tachs....how do you tell which is which?
I got a tach dash from a member here (can't even remember who) but now I'm wondering if it's for a 6 cylinder or a V8.
How can I tell? I saw a photo on another thread of a tach that had 8,000 as the last number, mine only goes to 5,000 rpms. I haven't hooked mine up yet but I'm wondering............ Anyone know how to tell the difference?
1972 Blazer - Bronco Orange - In the werks http://67-72chevytrucks.com/vboard/s...d.php?t=323444 1991 F250 - Hunting truck w/ Detroit rear locker, ARB front locker, front and rear winches .... and more.... 1997 Grand Cherokee - fun jeep - Detroit rear locker, ARB front locker, front winch, 411 gears, lots of lights ;-) 2004 Hot Rod DuraMax - Dnyo'd at the wheels with 525 HP and 1100 lbs torque.....mustang killer. |
06-23-2009, 10:27 AM | #2 |
Re: Tachs....how do you tell which is which?
There should be a stamp on the back of the tach (to the left of the wiring harness connector) that states 8cyl or 6cyl - that should be the easiest way.
06-23-2009, 10:33 AM | #3 |
Member #1049
Both tachs are 5000 rpm's... they normally have either 8cyl or 6 cyl stamped in ink on the back.. but alot of the time that has faded away.. other than that you have to either hook it up.. (the 6 cyl tach will read about 1200rpm at a 700rpm idle hooked up to a V8) or if you know electronic circuits and you and have two tachs you can take them apart and compare the values of a resistor inside..
06-23-2009, 10:58 PM | #4 |
Duh....I put that whole thing together a couple of times and never noticed the 8cyl stamp on it.....I'm good to go.
