Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 06-23-2009, 12:46 PM   #1
rlm316
rlm316's Avatar
WIW: 350tbi &700r4
What is a 350tbi &700r4 w/ wiring and computer worth? Thanks, Lane
rlm316 is offline   Reply With Quote
Old 06-23-2009, 12:57 PM   #2
clos69
Its Topless Season!!!!
clos69's Avatar
Re: WIW: 350tbi &700r4
We will need to see pics, what year and what did it come out of to start.Then we can go from there..
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 06-23-2009, 01:07 PM   #3
rlm316
rlm316's Avatar
It is out of a '95 1/2t truck.I'll have pics tomorrow. 150k on the clock. Thanks
Old 06-24-2009, 11:45 AM   #4
rlm316
rlm316's Avatar
pics
Old 06-24-2009, 04:04 PM   #5
79 silverado
If the engine doesnt puff smoke at startup from the valve guide seals being worn/dried up, and it doesnt drip out the rear main, and doesnt burn oil, and has good compression when tested, and throws no codes when jumping the aldl port, I would say $350-500 for the engine complete with harnesses and all wiring/everything to convert depending on your local supply/demand issues.
If the transmission is a 2wd, and doesnt have the gm reman tag hanging off it or some other documentation giving an impression of having less than the 150k on it, I'd say its worth $100-150... high mileage and they arent known for running forever.
If the transmission is a 4wd I'd bump it up to $150-200, assuming you include the tv cables, etc for someone wanting to convert etc.
Either transmission price depends on pulling the pan and having it be clean and not sludge filled on the pan, having nice clean fluid when up first open it up, and not having any clutch band material hanging around in there from it starting to wear, and no leaks from the shaft seals etc......
All of that said
It appears a sensor is unhooked, looks like it might be the IAC on the passanger side of the throttle body... make sure you run it with all the sensors connected and hooked up to ensure its functioning as it should before sale, and if it needs things replaced go on rockauto or somewhere and adjust your price accordingly...
79 silverado is offline   Reply With Quote
Old 07-13-2009, 10:13 PM   #6
crossy
Oh,you can't buy that new
crossy's Avatar
Lane, i ran mine (91)for a while run for $450 on craigslist and no takers, just tire kickers. Also at that price it could be heard run. The COMPLETE TBI systems bring OK money on ebay, but a lot of parts to package and the 87-91 set up, old body style, sell better because of 73-86 guys wanting them for changeover. get whatever you can for a 2WD 700R4 (actually a 4L60E in that year) . crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 07-19-2009, 09:40 PM   #7
arkracing
Weekend Warrior
Trans is a 4L60E if it is a '95. There is NO TV cable to shift it, it shifts by the computer only. It is only really good to someone who has one in the truck currently. I'd say $100-$125 with the said mileage.
The motor - approx $250-$350 ballpark without hearing it run. I wouldn't pull them untill someone comes and hears it run.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
