Old 06-23-2009, 12:48 PM   #1
ZombieWeinerDog
ZombieWeinerDog's Avatar
Octane Boosters?
i usually use regular pump gas. when i do get midgrade or premium, i see an increase in preformance. there is also a very small engine knock when using regular. will octane booster help me? i dont have the cash to spend buying midgrade and premium every fill up. anyone have any experience?
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 06-23-2009, 01:05 PM   #2
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
Re: Octane Boosters?
This is probably the most potent octane booster i've used
http://www.lucasoil.com/products/dis...tid=8&loc=show
Lucas Octane booster
mikajo39 is offline   Reply With Quote
Old 06-23-2009, 01:44 PM   #3
69GMCLonghorn
69GMCLonghorn's Avatar
I'm confused... You don't have the money for mid grade or super, but you have money for octane booster?
Also, if you're not running a high HP engine, maybe there is an engine issue. Check your timing, do all the usual tune up stuff (plugs, points, dist cap, rotor, etc). All this stuff could possibly help the pinging. I'm just not sure what you're running engine-wise, so that's the best advice I can dig up.
69GMCLonghorn is offline   Reply With Quote
Old 06-23-2009, 02:07 PM   #4
mikajo39
mikajo39's Avatar
I agree I only keep some octane booster with me when I might be somewhere that has crap gas, Whats your compression ratio, check your total timing around 3000 rpm if you can, or possibly switch to a colder plug range if you still ping.
Old 06-23-2009, 02:07 PM   #5
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
What's your timing at? Might be too much advanced and the super is trying to compensate. Octane boost is usually to help the older/high compression muscle car type motors or anything that has a high C/R. Most street engines will never "feel" a diff.....maybe in the mind only!
prostreetC-10 is offline   Reply With Quote
Old 06-23-2009, 03:14 PM   #6
69GMCLonghorn
I agree, with one addition... If you have an average engine that is worn out, Super can make a noticeable difference. I've experienced this on other vehicles.
However, I have to keep going back to what others have said (and myself), tune it up, tune it up, tune it up! Then see where you're at. Take away as many variables as possible and see where you're at.
Old 06-23-2009, 03:15 PM   #7
ZombieWeinerDog
well its not worn out, newly rebuilt a month or two ago.
1972 longbed- 454
1967 shortbed- 355
Old 06-23-2009, 03:41 PM   #8
killacheyenne
killacheyenne's Avatar
what all is involved in a usual tune up...i think my motor needs one but im not real sure what all to do
72 cheyenne super
83 chevy...4x4...454
killacheyenne is offline   Reply With Quote
Old 06-23-2009, 03:48 PM   #9
69GMCLonghorn
If it's a stock motor, "my" version of a tune up would be to change out the plugs, distributor cap, rotor, points (if you're running them), and maybe the plug wires if they look like they're getting old or cracked.
You might also change out any fuel filters you might have, as well as the air filter.
Once that is done, you want to set your base timing and idle speed. Adjust your mixture screws on the carb... What else am I missing?... Basically just take this time to look over the engine and see if everything is up to snuff.
Old 06-23-2009, 04:02 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i dunno about up in Michigan, but here, 89 is pretty much always 10 cents more per gallon than 87. Same for 91, 10 cents more than 89. You are talking 2 dollars added per fill up (from empty) for each jump in fuel grade. that ain't jack.
The octain boosters are misleading. One bottle won't raise the octain rating of a tank by the two or 3 points it claims. I can't remember what it actually does, but the label is VERY misleading, boarderline bogus.
If your engine is tuned, and you hear spark knock, then you need the added octain.
If your engine is not tuned, and you can't figure how to tune it better, and you hear the spark knock, then you still need the octain.
Remember, even race gas, is cheaper than new pistons.
Old 06-23-2009, 05:58 PM   #11
neonlarry
neonlarry's Avatar
When they say an octane booster raises the octane 4 points that is about 0.4 octane boost so 5 bottles would boost the average tank of gas two (2) octane. much cheaper to spend .10¢ extra per gal.
If you really want to carry some octane booster go to the hardware store and get a gallon of toluene. That will raise 10 gal of gas two (2) octane.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-23-2009, 06:15 PM   #12
prostreetC-10
My Carbon Footprint
The only other thing I would add is, depending on your level of ability, throw a kit in whatever carb you have. If its a quad or an Edel, a quick rebuild can make a big difference. Make it last on the list though. This all depends on how much your truck drives/sits and other factors.
Old 06-23-2009, 06:31 PM   #13
mclairmo
Pinging means detonation. I would use the premium gas all the time to make sure you are not putting holes in your pistons. Also, be sure the engine is tuned and timed correctly. Timing might be too advanced. Also, make sure engine is running nice and cool. Running hot will increase detonation. Run a factory fan shroud and use a factory clutch fan. Make sure water pump spins at the correct speed. Crank pulley should be larger than the water pump pulley to keep that coolant moving fast enough. Overdrive pulleys cause overheating. Make sure you have a large enough radiator that is nice and clean inside.
mclairmo is offline   Reply With Quote
Old 06-23-2009, 07:24 PM   #14
JimKshortstep4x4
neonlarry,
Is that one gallon of toluene added to a tank full to make the octane go up 2 octane? (On a 20 gallon tank).
I am glad that you brought it up about the points being a decimal and not a whole octane. I was taken in by the marketing ploy several years ago and was surprised when I added the booster with no results in reducing pinging!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-23-2009, 07:39 PM   #15
Pont406
Did you try running without vacuum advance? All you might need is a little less vacuum advance when running low octane. Try it before getting dip into it.
Pont406 is offline   Reply With Quote
Old 06-23-2009, 07:43 PM   #16
big mike71
big mike71's Avatar
I always use premium it's a average of about 3.50 more a tank.
big mike71 is offline   Reply With Quote
Old 06-23-2009, 11:36 PM   #17
Longhorn Man
Just using your post as an example, it may or may not apply to you.
If you use premium fuel, and the engine doesn't need it, then you are literally blowing money on something you don't need and has no benifit. Some engines will actually perform worse, pollute more, and get less MPG when too much octain is used.
Remember, octain levels measure the resistance to ignition. Has nothing to do with additives, or cleaner fuel.
Old 06-24-2009, 12:28 AM   #18
hwyix
This is very true.
If your engine is not tuned to take advantage of the higher octane you might be doing more harm than good.
That being said at least here in CA I notice a big difference from the cheap gas Arco/no name gas station to the Chevron/76.
hwyix is offline   Reply With Quote
Old 06-24-2009, 02:06 AM   #19
85gmc2tone
try this site first and read about octane boosters
http://www.rockettbrand.com/techsupp...bulletins.html
here is what i have used
NOS Octane Boost Racing Formula
NOS® Octane Booster Racing Formula
NOS® performance for the serious enthusiast. Developed to increase octane effect up to 7 points. Blended with MMT and our performance-enhancing Powertane, along with Nitromethane and unique lubricants specially developed for high performance engines.
Suggested Applications:
Recommended for racing combustion engines including carbureted, fuel injected, turbo and super charged. Excellent smoke suppressant for 2 stroke engines, Recommended for high-performance engines plus marine, industrial, lawn, farm and recreational. NOT recommended for use on diesel engines of any type.
85gmc2tone is offline   Reply With Quote
Old 06-24-2009, 02:11 AM   #20
85gmc2tone
heres booster reviews
volvospeed.com/Reviews/octane_boosters.htm
Old 06-24-2009, 08:50 AM   #21
prostreetC-10
My Carbon Footprint
If you use premium fuel, and the engine doesn't need it, then you are literally blowing money on something you don't need and has no benifit. .
I completely disagree!!! I use octane booster in my lawn mower and I can mow my lawn in half the time!!!
Good info. I wonder how much of that "104+ octane booster" was sold just because of the flame on the bottle?? Sure looks good on the shelf.
Course.....nothing will compare to the most marketable word of all time: BILLET
Old 06-24-2009, 12:32 PM   #22
ZombieWeinerDog
well, the ping goes away when i put midgrade in
timing is set around 0
1972 longbed- 454
1967 shortbed- 355
Old 06-24-2009, 04:01 PM   #23
neonlarry
neonlarry's Avatar
Originally Posted by JimKshortstep4x4 View Post
neonlarry,
Jim
1 gal toluene / 10gal of gasoline or 10% toluene for 2 octane boost.
Old 06-24-2009, 07:21 PM   #24
prostreetC-10
My Carbon Footprint
You have your timing at TDC???
That's zero
Old 06-24-2009, 08:22 PM   #25
ZombieWeinerDog
brand new carb
1972 longbed- 454
1967 shortbed- 355
