so i was taking my guage cluster off and i can get everything loose and off except for the headlights knob.....how does it come off??
![]() 83 chevy...4x4...454 |
Re: gauge cluster question
If I remember correctly, there is a tiny screw in the black knob, kinda round the side of it, should be a flathead. Take that screw out and the knob will come off. Under that there is a chrome piece that unscrews and a nut underneath that you'll take off, then it should come right out.
thanks ill give that a try
Hey, I think I told you wrong...one other thing to try, feel up on the back of the switch, there may be a button or something on top of it. Push down on that and the knob and rod will come pulling out. I think I was thinking of the wiper switch.
425hp409
![]() Join Date: Oct 2008
Maddog1331 is correct, the wiper knob is held in place with a small screw, but the headlight knob and shaft come out in one piece by pushing in a small button on the switch behind the dash and pulling on the knob. To reinsert it, just push it in the switch and it will snap into place.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
Correct but usually requires alot of jiggling as they bind up from corrosion. Play with it being a little forceful if it's stuck.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
This is the kind of info I usaully find out after I broke something.
What?
Be prepared to monkey with that for a while, and at the same time getting a sore thumb from pushing in that little button!
![]() I hate having to take mine apart just for that reason... Though there have been times it just comes right out, but more so of the time it takes a while and some swear words.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
