Old 06-23-2009, 07:08 PM   #1
ceck71
Need some help with change to 71 chevy 4 wheel to 2 wheel
Hi I'M new to this site Ihave a 71 chevy and thinking of lowering it and putting 18 ' or 20' inch wheels on it .what size tire ? and wheel off set ? and bolt pattern 5 lug. thank you . the truck is currenty 4 wheel drive on 37 inch tires it will be a big change for me .
ceck71 is offline   Reply With Quote
Old 06-23-2009, 08:20 PM   #2
ceck71
Re: Need some help with change to 71 chevy 4 wheel to 2 wheel
Trying to put pictures on. Can't get it to work.
Old 06-23-2009, 09:25 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Make sure you resize the pics to get below 100kb's or it wont work.
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 06-24-2009, 03:57 PM   #4
ceck71
if Ido I will have a lot of 4 wheel stuff for sale I wiil post pictures later.
Old 06-24-2009, 04:03 PM   #5
mclairmo
I would sell the 4x4 and obtain a 2wd to lower it. You can sell the 4x4 for more and buy as 2wd for less. To switch the 4x4 over to a 2wd would cost you much more than just buying a 2wd to begin with. However, if you want to keep the 4wd and just lower it, I assume you can just use lowering blocks on all 4 corners to get it down. However, 4wd is heavy and will ruin your fuel economy. Why not just keep it stock and get into off roading?
mclairmo is offline   Reply With Quote
Old 06-24-2009, 05:37 PM   #6
ceck71
Thanks the truck is in such good shape it is a factory ac cab it was orginally a 2 wheel drive I made it a 4 wheel drive it is now on a 79 frame 456 gears , 4 wheel disc brakes reverse shackle lift 3/4 ton springs no lift blocks. it is done right never seen mud very very clean.
Old 06-25-2009, 07:09 PM   #7
ceck71
I want to know what drop and tire & wheel sizes . please
