![]() Join Date: Jan 2009
question about pedals
my project is currently a 3 speed and converting to auto..... can i remove the clutch pedal and use what i havewith no modifications/ problems? keeping the manual brakes so no changes on the other side of the firewall thanks
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
Re: question about pedals
I've been told that you can just "unbolt" the clutch pedal assembly from the brake assembly & it works a-ok. Somebody who has done it on this site will have to confirm it though...
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
its all about the +6 inches
thats how GM did it
The Older Generation
If you unbolt the arm that the clutch rod fastens to and remove the spring the clutch pedal and pivot shaft will slide out to the left. Watch the spring it has a lot of tension on it. LockDoc
