06-24-2009, 06:55 PM | #1 |
454 Conversion
I figured its finally time to replace the 305 in my truck now as its using huge amounts of oil and I would like to put in a 454.
I was just wondering what sort of modifications I would have to do to get it to fit in my 1984 K10 with the 4spd trans. It has the 11 7/8inch clutch in it. I was told that the engine mounts would need to be changed but thats about all I know Any help would be appreciated.
Its no disgrace being poor. Its just inconvenient. |
06-24-2009, 09:35 PM | #2 |
Another Day, Another Dollar
Re: 454 Conversion
what do you have for a rear end?
keep in mine the amount of torque output a 454 gives!
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
06-25-2009, 07:12 AM | #3 |
Re: 454 Conversion
I have no idea what kind of axle it has but the RPO tag says it has the standard axle.
06-25-2009, 08:18 AM | #4 |
Re: 454 Conversion
I don't know much about the standard transmissions in these trucks, but I do know the bell-housing bolt pattern is the same between small block and big block. So your transmission should bolt up no problem. I have no idea about the clutch related stuff. My guess is what you have should bolt up to a 454 flywheel, but hopefully someone else will chime in. You also need to make sure the block you use has a provision for the Z-bar.
As for the engine, I did a 305 => 454 swap in my '86. I was told the small block engine mounts would work, but I had trouble lining them up. I ended up using some engine mounts from a '77 truck I parted out that had a BB factory. For exhaust I used some Hedman Hedders and they fit pretty good, but hang a little too low for a lowered truck. You will need to upgrade your radiator to a 4-row core. Other than that, it is pretty much a cake walk to drop a BB into these trucks.
- Greg |
06-25-2009, 08:43 AM | #5 |
Re: 454 Conversion
Years ago I had an 84 3/4t 4wd. Had a 408 SBC, dropped in a 454. Tranny bolted up, (turbo 400), took the mounts off the 400 engine, bolted them up to the 454, and dropped it in. You will need the pulleys and power steering pump off the 454, SBC won't be a bolt on. As long as you have a 454 flywheel, the clutch will bolt up too. Gonna need a 4 core rad, find one off a 454 or a diesel truck, they should have the biggest rads in them already.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
06-25-2009, 10:53 AM | #6 |
Re: 454 Conversion
[QUOTE=454HO;3378972] You also need to make sure the block you use has a provision for the Z-bar.QUOTE]
Whats the Z-bar?
Its no disgrace being poor. Its just inconvenient. Last edited by 1984Silverado4x4; 06-25-2009 at 10:53 AM. |
06-25-2009, 10:56 AM | #7 |
Re: 454 Conversion
I am swapping a 350 for a straight six in my 81 C10 and heard about the Z bar, what is it?
1981 C10 SWB 350 (in progress) 3 on the Tree "Old Bess" 1996 K3500 Crew Cab 454 4L80E "Family Camper" 2002 GMC 1500 Yukon XL 4WD "Wife's Ride" |
06-25-2009, 12:04 PM | #8 |
Re: 454 Conversion
The Z-bar was until recently a strip joint in the lower end of.....just kidding. It's really a mount from the frame rail to the engine with provisions to mount clutch linkage.
06-25-2009, 08:47 PM | #9 |
Re: 454 Conversion
Thanks for the help guys.
I have yet to find a 454 to buy so itll be awhile yet before this happens.
06-25-2009, 09:03 PM | #10 |
Happy to be here
Re: 454 Conversion
Your best bet would be to locate a truck with a 454 and buy it. Pull everything you need for the conversion and part the truck out..
Like this- LINK
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 06-25-2009 at 09:09 PM. |
06-25-2009, 09:24 PM | #11 |
Re: 454 Conversion
I like the idea but I dont have $1000 or more to spend all at once and my parents wont let me have any more vehicles.
(that truck looks to nice to part out anyway)
Its no disgrace being poor. Its just inconvenient. Last edited by 1984Silverado4x4; 06-25-2009 at 09:27 PM. |
06-26-2009, 08:13 AM | #12 |
Re: 454 Conversion
Then you better stick with the 305 you already got. Much cheaper to do a basic rebuild on a small block than to swap in a big block. And you could make that 305 run pretty good with some vortec heads, matching intake and a mild cam.
- Greg |
06-26-2009, 10:02 AM | #13 |
Happy to be here
Re: 454 Conversion
Good advice...
