Old 06-24-2009, 11:47 PM   #1
1964C10
1964C10's Avatar
Junk yard find or not
I have not been able to find a fuel tank for my truck that will go behind the rear wheel, the junk yards pull them or punch holes in them. I dont know if that is law here or something. Anyways, I visit the only u-pull-it yard here fairly frequently because they get alot of older trucks in. Well I did find anything today and was about ready to leave when I spotted this sitting in the crusher bin, it had an v6 motor banged into the side putting a small dent into it.
Anyways, I wanted to know if this is a find or a total bust. It measures 29"X21"X10.5" on the thickest part and it has 22 embossed in it so I suspect it is a 22 gallon tank. However I have no idea where it came from. It is a side fill tank which I want. The main question I have is, it will take quite a bit of cutting on the framerails to make it fit, will that be a problem strenght wise. The second thing I wonder about is the sending unit. I dont know much about fuel tanks could anyone chim in and let me know if this is chevy,ford,dodge etc. Any other advise or input would be greatly appreciated!!
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 06-25-2009, 08:43 AM   #2
1964C10
1964C10's Avatar
Re: Junk yard find or not
36 views and not one opinion, I am dying here guys! I will try to post some pictures later to today with the tank up against the frame and see what it looks like. Any ideas on what that sending unit opening looks like and goes to? All the help would be greatly appreciated!
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 08:48 AM   #3
daverod
SSN 706
daverod's Avatar
It looks to tall on the top part above the flange. My measured about 4-5" above the flange. The flange of the tank sits on the frame. I think yours is to narrow. Mine measured 31x31 flange edge to flange edge. I don't think triming the frame 1/2 or so really effects in to much. Maybe if your pulling a big trailer or carring heavy loads but I doubt it effects it much.
daverod is offline   Reply With Quote
Old 06-25-2009, 09:05 AM   #4
1964C10
1964C10's Avatar
Thanks Dave! I went and measured mine and flange edge to flange edge is 33 3/4" X 23" So I am pretty sure it needs to hang underneath which I hope wont be too bad since it is only 10" tall, however it needs to go in between the rails far enough so that the filler neck clears the top of the frame rails.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 09:21 AM   #5
daverod
SSN 706
daverod's Avatar
I'm not sure but I don't think you can have anythink sticking above the rails. Maybe if your going to raise the bed of your truck? Look on my thread and see how mine sits. The first tank I had sat to high and it messed with the bed supports.
Old 06-25-2009, 10:31 AM   #6
1964C10
1964C10's Avatar
Thanks Dave! I read your whole thread (again lol) and see what you did with your tank. I am going to check to see if I can still do the same Thanks for all the advice and nice build you got!!
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 05:43 PM   #7
1964C10
1964C10's Avatar
Went home during lunch and snapped some shots of the tank on and underneath the frame. I MUST be out of mind! that tank is huge although 22 gallons would be sweet!
In order for it to go all the way up above the frame I would need to almost cut completely through the flanges of the frame so that is a no go. I am looking at raising it into the frame maybe about 3-4" and having the fill neck through an opening in the frame. What do yall think?
An other option would be to section the tank in half and cut out the middle section but that is of course alot of work plus I would lose the benefit of the large tank. That kinda leads into another concern, is 22 gallons too much for that frame as it sits stock? will I need to reinforce it?
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 05:58 PM   #8
joe231
joe231's Avatar
I would say find another...that is going to be way more work than it is worth....
CHEVY ONLY
Old 06-25-2009, 06:03 PM   #9
1964C10
1964C10's Avatar
Yeah that is what I am leaning towards as well, the problem is here they are impossible to find so that would mean I would have to buy a new one which is a mucha mulla for this build.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 06:08 PM   #10
joe231
joe231's Avatar
there was a link awhile back for a new van tank for around $100 from a parts supplier, believe it was on 502tripower's build thread...
CHEVY ONLY
Old 06-25-2009, 06:13 PM   #11
1964C10
1964C10's Avatar
Thanks Joe, reading it now....
Btw the tank midway on this page looks alot like the one I have.
http://67-72chevytrucks.com/vboard/s...=327024&page=2
I guess it could be a bronco tank.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 06:19 PM   #12
daverod
SSN 706
daverod's Avatar
That things a monster. Looks like the first tank I tried it was a 33 gal. It fit but it was to high. Stodder found one but it had a hole in it. Why not just weld the hole shut. Around here every car/truck in the junk yard has a tank in it.
Old 06-25-2009, 06:27 PM   #13
1964C10
1964C10's Avatar
hahahah yeah it is a monster! didn't look that big at the yard, looked just perfect hahaha. I can't even find one with a hole in it, I have asked at the pull it yard but they wont "save" me one, they are scraped the same day come in, must be something environmental or something.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 06:34 PM   #14
daverod
SSN 706
daverod's Avatar
Damn tree huggers. Just kiddin. Probably a good idea. Here they take them out, drain them, put them in the back of the truck.
Old 06-25-2009, 06:40 PM   #15
1964C10
1964C10's Avatar
That makes perfect sense! but then I dont work as a lawmaker/tree hugger. I mean for crying out loud there are warning labels on the pump that gas has shown to cause cancer...."no thanks on the martini, I'll just have some 91 octane"
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 06:52 PM   #16
daverod
SSN 706
daverod's Avatar
I think everything in Cal. causes cancer. I live in Idaho so I'm safe. Except for West Nile and Beaver fever. Oh and Brucellosis, Chronic wasting and Lyme disease.
Old 06-25-2009, 07:12 PM   #17
1964C10
1964C10's Avatar
Rough calculation that this is a ~28 gallon tank, meaning 180 lbs of weight, that shouldn't be too bad.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 07:17 PM   #18
daverod
SSN 706
daverod's Avatar
Is that leaded or unleaded? 5.93-6.42lbs per gal. I would'nt worry about it unless your towing somthing or if a corn fed sits on your tailgate.
Old 06-25-2009, 07:27 PM   #19
1964C10
1964C10's Avatar
Found the tank online, it's a ~1975-1985 Ford Econoline fuel tank, 22 gallons.......can't bring myself to put fjord part in my truck....guess it's going on CL.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 07:27 PM   #20
1964C10
1964C10's Avatar
that rules!
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 06-25-2009, 07:57 PM   #21
daverod
SSN 706
daverod's Avatar
What about this. CL Sandiego 1970 1971 1972 chevy truck gas tank. Says he has Blazer stuff to?
Old 06-25-2009, 09:59 PM   #22
1964C10
1964C10's Avatar
Thanks Dave!! when I looked at the ad it is a in-the-cab tank. I shot him an email and see if he might have someting. I also found someone in victorville although that is a bit of drive.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
