06-25-2009, 08:51 AM | #1 |
How to question
I am planning on going to the junk yard today to find the parts to do the front power disc brake setup (spindles, arms, tie rods etc). My question is, while I am there how do I get the upper/lower arms apart with the spring knocking me in the head? At home I have the jack to do that, I was wondering if there was a trick or do I need to bring a bottle jack, wooded blocks and so on? Thanks all!
1964 Fleetside LWB 1995 Yellow Mustang convertible 1996 Camaro Z28 My build thread Looking for help on completing the Disc Brake Upgrade Reference Thread If you didn't build it, you don't really own it |
06-25-2009, 08:59 AM | #2 |
Re: How to questionp
Sorry about the subject line, guess that is something that you can not edit.
06-25-2009, 09:51 AM | #3 |
Registerd User
I would use a jack on the crossmember. Lower a-arms on the ground. Remove lower ball joint nut. Wack the chet out of it till it breaks loose. Remove nut. Jack it up slowly till the springs fall out.
06-25-2009, 09:51 AM | #4 |
SSN 706
I taped my grinder on a stick stood back about 8' and cut the u bolts.I know it's not the right way to do it but it's my way and it worked. Did'nt really seem like there was a lot of pressure on them anyways. I think they make a spring compressor that you rent from Auto Zone. I was to just lazy to get one. You could hook a chain around it and hook it to something if you think it going to come flying out of there.
06-25-2009, 10:33 AM | #5 |
Thanks guys! Now that you mean it I do have a spring compressor that I used for my mustang, I'll see if it fits. They work good just take forever to get them on and off, but better then losing a body part lol.
06-25-2009, 01:14 PM | #6 |
SIR
..find a 72 if possable,borrow there torch cut the frame off at the firewall and take the whole thing home and disassemble it at your leasure...my "02"..
66long low fleet http://community.webshots.com/user/LVNR66 |
06-25-2009, 01:49 PM | #7 |
Rods
LOL dont take the nut off. Just loosen it up Whack it on the flat spot on the spindle. The nut will stop it form coming off. then put your jack under it use a 1/2 long handle ratchet and take the nut off.
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) Last edited by 70 Suburban; 06-25-2009 at 01:49 PM. |
06-25-2009, 02:52 PM | #8 |
Registerd User
I know. Edit time ran out.
06-25-2009, 03:13 PM | #9 |
Good idea, maybe in conjunction with the spring compressor and a jack it will be "safe" lol
06-25-2009, 03:14 PM | #10 |
That would be the ideal situation but I have no way to transport it home. The bed is off my truck and I dont know anyone crazy enough to let me drop a greasy, rusty old front end in their truck/van hahahaha...I need new friends
06-25-2009, 04:31 PM | #11 |
just tie some rope around the spring then tie it to the frame so it can't jump out.....take the lower ball joint nut off and swing your BFH, as you stay out of the way of the lower arm.....
I went and got a spindle from a junk yard, the guy pulled it with a pair of pliers, adjustable wrench, and a BFH as stated previously, there doesn't seem to be much tension.
CHEVY ONLY |
06-25-2009, 05:05 PM | #12 |
Hope that will be true for me ...doesn't look like today though, I am still working.......at least my plans for my truck are going better then my plans to be independently wealthy
06-25-2009, 06:00 PM | #13 |
you get the second deal figured out, please let me know
CHEVY ONLY |
06-25-2009, 06:08 PM | #14 |
I am sure that this truck is not a good "financial" investment
06-25-2009, 06:23 PM | #15 |
SSN 706
06-25-2009, 06:31 PM | #16 |
SSN 706
I did'nt read you have no way of tranporting it.You mean you hav'nt cut your parts truck in half and made a trailer out of it yet?
06-25-2009, 06:37 PM | #17 |
Hahahaha...no parts truck here....I dont really live in a neighborhood where I have room for things like that. I have also been reading up on all the parts I will need and I am still a little confused, so more research needed. I am going to be running discs with a power booster, but I would like to have the 73-87 parts (I think the years are correct) so that replacement parts are more abundent.
06-25-2009, 06:42 PM | #18 |
SSN 706
71 and 72 will work also. If your hard up.
06-25-2009, 06:45 PM | #19 |
It's not an urgency so if I have to find some parts now and get some later then that is fine as well, but thanks for the heads up, I am adding it to my list of potential parts.
06-25-2009, 11:53 PM | #20 |
60-66 Nut
Most guys go for the '73-'87's partly because they are more abundant in the salvage/junk yards. I seem to remember that the lower balljoint for the '71-'72's are more expensive than the '73-'87's also.
06-26-2009, 12:16 AM | #21 |
SSN 706
The lowers are the same the uppers are a $14 difference.
06-26-2009, 12:22 AM | #22 |
Thanks guys, one step closer, well probably two since I know what I am hunting for.
06-26-2009, 09:21 AM | #23 |
I would let you drop it in my truck. But then again the comute might be rough,..
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
06-26-2009, 09:24 AM | #24 |
SSN 706
Nice offer. What about tieing it on top of the old ladies car. I saw a guy at the lumber store with a 6x16 beam on his wagon.
06-26-2009, 09:52 AM | #25 |
thanks for the offer fleetside! that is most gracious! what I might end up doing is renting a truck from Lowe's I think they are like $20/hour.
