01-04-2003, 03:26 PM | #1 |
engine misfire question
i have a 69 step w/ a 327...HEI timing set to 8 deg. btdc...bosch +4 plugs...and a Holley carb.
My question is...under hard accel...usually around 3500 - 4000 rpm...there is a backfire coming from the motor...hard to tell if its in the exhaust or exactly where....what would be the most likely cause for this...thanks.Ken
94 K1500 SWB w/ 4" body and suspension lift |
01-04-2003, 05:57 PM | #2 |
anyone ??
01-04-2003, 07:21 PM | #3 |
maybe the your cam has a lobe worn round had one do that to me once,backfired throu carb thou.
good luck
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
01-04-2003, 08:20 PM | #4 |
If it only happens under acceleration, I would say your carb's set too lean. Fuel starvation will cause a miss (not a backfire, though) under acceleration. Mine was missing under load and it was the fuel settings.
RLTW 70C10 72K10 72K10 Cheyenne 72C10 Cheyenne Super |
