blazer doors ,can use reg truck doors?need help
my blazer needs doors,i really dont know if i can use reg truck doors or suburban doors? advice and pics would be great thx for the help
![]() Join Date: May 2007
Re: blazer doors ,can use reg truck doors?need help
Absolutely. I just turned a set of 71 pickup doors into 72 blazer doors. I used to have to do this yearly on my rock crawler. I will try to get some pics up this weekend. If you look in the factory assembly manual this is what they did at the factory. I believe all blazer doors were born as truck doors.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
urban fourwheelin
I know 72 are different. How do you turn other year doors in to 72 doors.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
![]() Join Date: Dec 2008
The main difference is there is a small screw hole by the vent window, I don't think that there is any other major differences, But I may be wrong.
Yep, to my knowledge just the screw hole is different on a 72. Blazer doors also have an aditional support plate around the latch. It is a simple conversion. Good blazer doors seem to be next to impossible to find. I will try to post pics of my doors this weekend.
urban fourwheelin
so you just drill the hole and that is it? It kinda recessed in the door. if i remember correctly.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. Last edited by RED72blazer; 06-25-2009 at 03:07 PM. |
As far as the window frame, remove your plastic pieces and cut off frame just like your blazer door. For the hole I cut the area out off my original doors and welded into my "new" doors. You will have to drill a hole into the lip on the outer skin and install the little clip for the screw. If you look at your doors you will see it is pretty self explanatory. For the latch reinforcement drill out the spotwelds to remove plate and weld to your door. Even if you haven't done bodywork if you look at how the factory modified the original doors you will see that it is fairly simple to modify truck doors. Sorry I didn't have more step by step pics. I was in a hurry to get them done and didn't take as many as I should have.
In the FAQ section:
http://67-72chevytrucks.com/vboard/s...d.php?t=273729 An excellent thread about doing exactly what your asking about. Here's another place to spend good quality time: http://67-72chevytrucks.com/vboard/s...d.php?t=307709 Last edited by vtblazer; 06-26-2009 at 06:02 AM. |
Thanks for passing that on VT. I hadn't thought about doing a thread when I did mine. I will have to keep that in mind for future mods on my blazer!
