01-04-2003, 03:50 PM | #1 |
Garage Queen Material
more than rearend problems
well, as i went out to retighten my ubolts like it said to do at 300 and 500 miles, i noticed that not only my passanger side rear tire sticks out more, but also my passanger side front tire sticks out more then the front drivers side.
they both stick out probably a good half inch if not more. that makes me think that it was like that before, but i didnt notice since my truck was stock height |
01-04-2003, 06:49 PM | #2 |
lol your truck has been wrecked... HAHAHA
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
01-04-2003, 07:53 PM | #3 | |
now how do i fix it? |
01-04-2003, 07:59 PM | #4 |
i would have the frame put on a machine and checked...i have to do it to mine.
01-04-2003, 08:22 PM | #5 | |
01-04-2003, 08:24 PM | #6 |
BAD BOW-Silverado XST
The front tires will stock more than the current stock stance due due the drop. I already hate the way the front tires stickout on mine. Wonder why GM made these trucks wider on the front than the rear?
01-04-2003, 08:36 PM | #7 |
eric, do you know if your truck was ever wrecked before? seriously? i know mine was. the frame is already bent.. and the front and rear were different colors...not by much but they were..i dont know. doesnt really make sense. i cant see why they both stick out the pass side more...you could try the frame.. but i dont know...
01-05-2003, 12:31 AM | #8 | |
http://coloradok5.com/forums/showfla...rue#Post505552 I personally think it is so tires don't follow the same ruts, but there's no definitive proof. -- Mike
http://home.houston.rr.com/chevy73/ |
01-05-2003, 03:41 AM | #9 |
STILL PLAYS WITH TRUX
Eric,
I dont know where your truck took the blunt of the hit but you may want to visually inspect all of the body mount bolts and rubber isolation muonts for damage maybe the whole body has shifted to one side as a resault of the accident and i would still have the frame checked as well. |
01-06-2003, 12:24 AM | #10 |
Whats this wire for?....
maybe just as simple as the offset on the rear 2 rims is different than the front 2 and you have a rear & front switched on one side.
Kyle CANADIAN CONNECTION '82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders |
01-06-2003, 01:12 AM | #11 | |
