Old 06-25-2009, 04:28 PM   #1
69GMCLonghorn
69GMCLonghorn's Avatar
Ammeter Gauge
Who knows anything about these gauges? Mine has never worked. The needle just sits in the middle of the gauge. I've replaced the gauge itself and the printed circuit board and I've never even seen the needle twitch, even when my regulator crapped on me and the voltage when through the roof. I've done my best to check the connections that weren't wrapped up in the harness, no blown fuses, etc... The only thing I have now done is converted to an internally regulated alternator. But even before that, it never worked.
I have since installed a run-of-the-mill $10 volt meter under the dash, but I'd like to get the ammeter working too. Any suggestions?
69GMCLonghorn is offline   Reply With Quote
Old 06-25-2009, 04:39 PM   #2
69sixpackbee
Re: Ammeter Gauge
What year?
69sixpackbee is offline   Reply With Quote
Old 06-25-2009, 04:41 PM   #3
69sixpackbee
Re: Ammeter Gauge
Check Here:
Old 06-25-2009, 05:09 PM   #4
neonlarry
neonlarry's Avatar
Re: Ammeter Gauge
Have you checked the two 4amp fuses in the black rubber cases on either wheelwell?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-25-2009, 07:21 PM   #5
Thealien
Thealien's Avatar
Re: Ammeter Gauge
That was my problem
