Old 06-25-2009, 04:59 PM   #1
tucnnuts
if they can make it so can I!
tucnnuts's Avatar
bagged trucks and hanger bearings
ok guys need some help ... i am havin some problems with a bad drive line vibration...iam pretty sure it is cause the angle it is at...it is alot better with the truck raised up but still there at low speeds....i have put a slip yoke on the rear driveshaft to releave the hanger bearing, i was just wonder if anybody thinks like and heavy duty pillar block would work...somthing with out the cushion mount like stock,the cushion seems to let it vibrate to bad
tryin not to cut out the cab for a one piece shft...thanks for any info...
tucnnuts is offline   Reply With Quote
Old 06-25-2009, 05:04 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: bagged trucks and hanger bearings
are the u joints in line like they should be?? they call it fazed
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 06-25-2009, 05:11 PM   #3
tucnnuts
tucnnuts's Avatar
yeah i do alot of four wheel drive shafts...they are in faze..iam think its at such a great angle that the cushion in the center support bearing is letting it vibrate...
Old 06-25-2009, 06:25 PM   #4
Hottrucks
Hottrucks's Avatar
I don' know how much drop you have but with a 2.5" c notch I have driven mine that way to over 100 mph with no repercustions....I would get under it and see if you can move anything something is out of wack
Old 06-25-2009, 06:51 PM   #5
project 67 sub
project 67 sub's Avatar
hey tucnnuts, mine is the same way as yours. its got a new slip joint shaft on the rear and the front one has been redone, and i get the vibrations as well. mine is lowered 9"s in the rear, and like said mine has a vibration as well. i think that the vibration that we are having is because of the pinion angle, it ends up being pointed down like the tail shaft of the transmission the lower you go, and it should be pointing up about the same degree as the tailshaft of transmission is pointing down.
p.s. hope this helps and good luck.
project 67 sub is offline   Reply With Quote
Old 06-25-2009, 07:26 PM   #6
Hottrucks
Hottrucks's Avatar
I think he has a 2 piece shaft??? check the bolt where the carrier is??? the one behind the u joint???
Old 06-25-2009, 07:28 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
If it's a 2-piece the New Porterbuilt Crossmember might be the answer?
http://67-72chevytrucks.com/vboard/s...d.php?t=328095
LUV2XCLR8 is offline   Reply With Quote
Old 06-26-2009, 12:44 AM   #8
project 67 sub
his is a 2-piece drive shaft and so is mine
Old 06-26-2009, 04:38 AM   #9
VA72C10
VA72C10
VA72C10's Avatar
I've heard to flip the carrier bearing when you're going around/over 6" of drop to eliminate the poor angle...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-26-2009, 03:52 PM   #10
project 67 sub
^^^if anyone has anymore info on that i would like to know and hear how it went
Old 06-26-2009, 04:00 PM   #11
VA72C10
VA72C10
VA72C10's Avatar
Here's the link to IvelDesigns 69 longbed build
http://67-72chevytrucks.com/vboard/s...=212747&page=2
and the post about it so you don't have to go through all the pages...http://67-72chevytrucks.com/vboard/s...8&postcount=31
Old 06-26-2009, 04:52 PM   #12
tucnnuts
tucnnuts's Avatar
well i built the frame to let the crossmember come up enough to lay the frame...so i have got the 5.3l motor down far as i can get it with already 3.5 notched into the cross member..so the trans sits up high in the frame ...so the angle frome the trans to the hanger bearing is downward and then up to the rear end...iam thinking its like when ya use a wiggler socket..the greater the differance and the angles its harder to control where as on a stock truck they are alot more inline, mines at a bad angle all the way down...so i was goin to fab a hanger bearing up that was alot stronger than the 18 gauge one from the parts store, but then i worry if even if the hanger bearing want break(again..killed two so far) are the ujoints not going to take it...i just dont want to cut the cab out for the single shaft..i have already built a speaker box under the seat and wanted to make the back window roll down so i need all the space behind and under the seat....
Old 06-26-2009, 05:01 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i would go to the drive shaft guys and get there advice. They know the max angles and all that. They also have the knuckle u-joint set up (ford design) that works way better than a single U-joint in this kind of aplication.
