Old 06-25-2009, 07:16 PM   #1
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
wing window on an AD
Is it possible change out the hardware where the spring and the bolt attach to the window? On my drivers side the "bolt" or attaching point for the window on the bottom broke. How do I fix it? Thanks guys!
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 06-26-2009, 07:34 AM   #2
Houston54
Re: wing window on an AD
You can access this hardware by taking the door panel off. There is an access opening in the door so the vent pivot can be adjusted.
The bad news is that if the pivot post broke away from the vent frame you may have to find a replacement. Rewelding the post to the frame is a possibility but it is not a permanent solution and will break again.
Save that hardware (nut, washers, spring) as not all of it is reproduced. The vent windows are available through the various parts suppliers.
One good thing about this repair is you can do it without taking the entire vent frame/window channel out of the door.
Houston54 is offline   Reply With Quote
Old 06-26-2009, 08:57 AM   #3
bretcopsey
I think that assembly is riveted to the window frame. I have a couple extra frames I don't need. If the stud is good on either, it's your's-just pay shipping.
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 06-26-2009, 12:23 PM   #4
mylow53
mylow53's Avatar
nick i've got some springs if you need them
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 06-26-2009, 11:24 PM   #5
nickp51chevy
bretcopsey, could you gestamate how much shipping would be to 98223?
GT, I think that I still have all the hardware, but if I need something I will PM you. Thanks.
Had;
